Contact US
helical gearbox calculation
RE: helical gearbox calculation
If you have the gearbox, the manufacturer has specifications.
If you need to select a gearbox you need to find out things about your situation.
"Prime mover" type ( electric motor, steam or gas turbine, Conan ) Power, rpm, duty cycle, plant environment, space/envelope available for the gearbox, required reliability, budget , when the system must be up and running, and lots more.
Sometime belt drives are useful for driving equipment.
Question is way too open-ended. Do you have a particular reducer, ratio, motor, motor speed that you are working with? Manufacturer's literature will generally walk you through most applications. Call the reducer manufacturer and speak with an applications engineer - they know how to answer almost any application questions. Attached is a Falk helical and helical-bevel literature for reference. A lot of times the difficulty lies in calculating the required torque/power/speed of the machine, afterwhich the reducer practically sizes itself. Also make certain to understand the thermal capacity of the reducer, thermal power may be the limiting factor. (Also, your picture indicates a helical-bevel reducer, which will have somewhat different capacity that parallel-shaft helical gearbox.)
charls
I suggest a gear design handbook and a gear program. that has been proven
@ dvd (Mechanical),
Can't open attached file.. can you resend it
Charles
The file name has an ampersand in it. You can replace the ampersand in the download name with %26 in the URL.
For example;
https://files.engineering.com/download.aspx?folder=6e4cf149-98d0-4292-bc14-df3d67b4005c&file=Falk_-_A-Plus_Parallel_%26_Right-Angle_Shaft_Drives.pdf
Tmoose
What kind of prime mover type is Conan?
Thanks!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
