Contact US
ASME Section VII Div.2 part 5 | Elastic plastic analysis | Table 5.5
In an elastic-plastic analysis, the required factored load combinations from table 5.5 of ASME Sec VIII Div2 part 5, the table has temperature (T) as one of the load cases in a load case combination e.g. 0.88*beta*(P+Ps+D+T).
So, when factoring the temperature, I have used the factor on the coefficient of thermal expansion. Is there any other way to factor the temperature? or is this factoring reasonable?
Thanks.
Shiraz
Sr. Engineer
RE: ASME Section VII Div.2 part 5 | Elastic plastic analysis | Table 5.5
Using the factor on the coefficinet of thermal expansion is the right way to do it.
I concur with IdanPV.
Thank you IdanPV and TGS4 for the confirmation.
Shiraz
Sr. Engineer
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
