milwaukeebob
Hello forum members, please find the attached pic showing a ground riser termination a contractor made to an I-beam. It's understood this ideally would be a cadwelded connection but my question is related to them utilizing the same hole for the conduit strap as they did for the ground cable lug. There's alot wrong with this but could someone direct to the section of the Code that doesn't allow this.
