Friction Coefficient or Slip Critical Bolts
ac0609
18
Hi there,
I am doing some research on friction coefficients for slip critical bolts.
I am looking for the friction coefficient for SSPC-SP11 and SSPC-SP15 on surfaces with primer.
If anyone has any guidance with this, that would be great.
Thanks in advance!
- EN1993-1-8 suggests μ ( varies from 0,2 to 0,5),
- EN 1090-2 suggets μ=0.4 for Surfaces blasted with shot or grit and coated with alkali-zinc silicate or
thermally sprayed with aluminium or zinc,
- THe coefficient of friction may be obtained by testing,
- The faying surfaces normally should not be painted with standard protection paint as they reduce the coefficient of friction between the contact surfaces.
If you put garbage in a computer nothing comes out but garbage. But this garbage, having passed through a very expensive machine, is somehow ennobled and none dare criticize it. ( ANONYMOUS )
