Vapor Recovery Line - On/Off Valve - Seat Selection
McDermott1711
SG
There are several vapor recovery lines, which are used at gasoline loading bays. During the day, lots of tankers come and go and there is an on/off valve in vapor recovery lines that shall be normally closed unless a tanker is stopped for loading and at this time, its line shall be opened by actuation of the valve. Considering frequency of operation (opening/closing of the valve), which type of the seat is appropriate for this valve?
Nothing is more fairly distributed than common sense: no one thinks he needs more of it than he already has. Rene Descartes
Re. valve seat selection, steam recovery line. Any valve seat should be selected according to: Valve type, fluid components, pressure, temperature, flow (max/min), opening and closing time (max/min required), resulting valve size, acuator type etc. etc.
Apart from above missing information: In most (common) cases a ball valve with carbon filled ptfe sealing could be used, ss ball and valve. Note: exact opening and closing positioning, hairline opening likely to give cavitation.
Good luck!
