Locknut and screw problem
yrrh
IN
I am facing problem with locknut and bolt tightening . Describing it as I have one model which has breadth is 4 feet and width is 30 cm. problem is this while tightening the bolt and nut I have to keep hands downward to locknut and tight upper side with screwdriver that is creating problem in my back so what would be the solution on that ?
This was posted in thread1630-502362 earlier in February.
You should not cross-post in different forums or different sites.
Skip,
[glasses]Just traded in my OLD subtlety...
for a NUance![tongue]
