Contact US
Infra Red heater starter
Hello, All
I am working IR(infra Red)heater installation with heater starter on site. Electrical drawing provide one circuit for two IR heater with starter. It seems that starter was composed of timer, thermostat controller, contact relay and others. As each IR starter require own starter, so that incoming circuit to connect splitter, after splitter connected two fused disconnect switch for each IR starter.
Question, does it make sense two disconnect switch are fed on a circuit ?
RE: Infra Red heater starter
Hi! Yes, it makes sense to have two disconnect switches fed on a circuit in your scenario, as you want to provide separate control and isolation for each IR heater. This allows you to safely turn off the power to one heater without affecting the other, and also allows for individual control of each heater's temperature or timing, as specified by its thermostat or timer.
Having separate fused disconnect switches for each heater ensures that in case of a fault or failure in one of the heaters, the circuit breaker or fuse can quickly and safely disconnect the power to that heater, without affecting the other one. This is an important safety consideration and it is a common practice to have separate disconnect switches for each load in an electrical system.
Another way to look at it: how would you feel if all you had to do was pull ANY one door handle to open EVERY door (including the trunk and hood) on your vehicle? Having a separate means of disconnect is a good thing.
Converting energy to motion for more than half a century
Thank Maximillanrichards for your comment.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
