Adams car-Subsystem Modification
Yousif Alaraji
Automotive
TR
Dear Engineers,
Kindly I did some modifications on the front suspension I opened it on Template and then save it as a subsystem in the Standard model then when I tried to assemble it, It shows an error when I am trying to analyze it. Although the dampers.tbl/msc_0001.dpr exist, it shows that it was not found.
The error is accordingly:
Reading in property files...
ERROR: The property file referenced by the following element was not found:
ERROR: - fsae_frontsusp_changed.dal_ride_damper : mdids://fsae_2018/dampers.tbl/msc_0001.dpr
ERROR: - fsae_frontsusp_changed.dar_ride_damper : mdids://fsae_2018/dampers.tbl/msc_0001.dpr
Reading of property files failed.
How can I solve this issue?
Best Regards,
Yousif
