Contact US
Macro to read value dimension associate at Baloon
Hi all,
I am trying to write a macro with CATScript language that will read and print dimensional values associated with baloons;
attached is the starting situation and I want to get a msgbox that says: Baloon1 Value 50; Baloon2 Value 100; Baloon3 Value Ø25.69
I try to wirte this, but doesn't work:
Sub CATMain()
Dim drawingDocument1 As DrawingDocument
Dim drawingView1 As DrawingView
Dim drawingDimensions1 As DrawingDimensions
Dim drawingDimension1 As DrawingDimension
Dim DrawingDimValue1 As DrawingDimValue
Dim Selection1 As Object
Dim SavedLockStatus As Boolean
Set drawingDocument1 = CATIA.ActiveDocument
Set Selection1 = drawingDocument1.Selection
'Selection1.Search "CATDrwSearch.DrwDimension,all"
Selection1.Search "CATDrwSearch.DrwBalloon,all"
For i = 1 To Selection1.Count2
Set drawingDimension1 = Selection1.Item2(i).Value
Set drawingDimensions1 = drawingDimension1.Parent
Set DrawingDimValue1 = drawingDimension1.GetValue
msgbox DrawingDimValue1.Value
Next
Selection1.Clear
End Sub
RE: Macro to read value dimension associate at Baloon
Time has passed, but it looked like fun, so I gave it a try.
Running the following macro will display balloon information referencing the dimensions in the active sheet.
CODE --> vba
'vba
Option Explicit
Private Const tolerance = 0.001
Sub CATMain()
    Dim dDoc As DrawingDocument
    Set dDoc = CATIA.ActiveDocument
    Dim balloon_infos
    balloon_infos = get_balloon_info_referring_dimensions( _
        dDoc, _
        tolerance _
    Dim msg As String
    If IsEmpty(balloon_infos) Then
        msg = "There are no applicable balloons."
    Else
        msg = "Balloon Text : Dimension Values" & _
            vbCrLf & _
            Join(balloon_infos, vbCrLf)
    End If
    Debug.Print msg
    MsgBox msg
End Sub
Private Function get_balloon_info_referring_dimensions( _
    ByVal drawDoc As DrawingDocument, _
    ByVal tolerance As Double) _
    As Variant
    get_balloon_info_referring_dimensions = Empty
    Dim balloons As Collection
    Set balloons = get_balloons()
    If balloons Is Nothing Then
        Exit Function
    End If
    Dim infos As Collection
    Set infos = New Collection
    Dim balloon As DrawingText
    For Each balloon In balloons
        Dim dims As Collection
        Set dims = get_target_dimensions(balloon)
        If dims Is Nothing Then
            GoTo continue
        End If
        Dim msg As String
        msg = balloon.text & " : "
        msg = msg & get_values_by_dimensions(dims, tolerance)
        infos.Add msg
continue:
    Next
    get_balloon_info_referring_dimensions = lst2ary(infos)
End Function
Private Function get_values_by_dimensions( _
    ByVal dims As Collection, _
    As String
    Dim lst As Collection
    Set lst = New Collection
    Dim dimension As DrawingDimension
    For Each dimension In dims
        lst.Add Round(dimension.GetValue().value, tolerance)
    Next
    get_values_by_dimensions = Join(lst2ary(lst), ",")
End Function
Private Function lst2ary( _
    lst As Collection) _
    As Variant
    If lst.count < 1 Then
        lst2ary = Empty
        Exit Function
    End If
    Dim ary() As Variant
    ReDim ary(lst.count - 1)
    Dim i As Long
    For i = 1 To lst.count
        ary(i - 1) = lst.Item(i)
    Next
    lst2ary = ary
End Function
Private Function get_target_dimensions( _
    ByVal balloon As DrawingText) _
    As Collection
    If balloon.leaders.count < 1 Then
        Set get_target_dimensions = Nothing
        Exit Function
    End If
    Set dims = New Collection
    Dim leader As DrawingLeader
    Dim target As AnyObject
    For Each leader In balloon.leaders
        On Error Resume Next
            Set target = leader.HeadTarget
            If target Is Nothing Then
                GoTo continue
            End If
        On Error GoTo 0
        If Not TypeName(target) = "DrawingDimension" Then
            GoTo continue
        End If
        dims.Add target
continue:
    Next
    If dims.count < 1 Then
    Else
        Set get_target_dimensions = dims
    End If
End Function
Private Function get_balloons() _
    As Collection
    Dim sel As Selection
    Set sel = dDoc.Selection
    CATIA.HSOSynchronized = False
    sel.Clear
    sel.Add dDoc.sheets.ActiveSheet
    sel.Search "(CAT2DLSearch.DrwBalloon + CATDrwSearch.DrwBalloon),sel"
    If sel.Count2 < 1 Then
        Set get_balloons = Nothing
        Exit Function
    End If
    Set balloons = New Collection
    Dim i As Long
    For i = 1 To sel.Count2
        balloons.Add sel.Item(i).value
    Next
    sel.Clear
    CATIA.HSOSynchronized = True
    Set get_balloons = balloons
End Function
This is the result when the macro is executed.
There is a limit to the number of characters that can be displayed in the MsgBox, so if you have a large number of balloons, it may not be possible to display all of them.
Thanks a lot for the answer.
However I need the CATScript, but starting from VBA I can also trace the CATScript code.
Thank you very much, great job.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
