Thinking of building a pilot project for one of my customers wherein I install simple flow sensors on multiple machines and connect their outputs to an IIOT gateway. Now the issue is that because of budget restrictions, I can only afford very basic flow sensors meant for water (the hall effect ones) which give a Pulse Output. And the Gateway can only accept inputs in RS485 or 4-20mA.
How do I do this conversion? Will it cost a bomb? Because if a 'converter' is required per flow sensor, I may have to get many of those as there could be as many as 50 flow sensors required for this client.
