JIS Spline Standards
Hello All,
I'm currently working with a Japanese spline design and need assistance with finding a pdf of JIS spline standards.
Does anyone have a copy or know where I can obtain a copy?
I've also added the as found measurements for the internal spline I physical have with me. I do not have the mating external splined gear.
Internal Splines/Gear Data:
Numbers of Splines = 47T
Nominal Dia. = Ø98mm
Mod = 2 (Best Guessed)
Dia. Pitch = Ø94mm
Minor Dia. = ~Ø3.5437" (~Ø90mm)
Pin dia. = Ø0.131" (Ø3.3274mm)
Over Pins dia. = Ø97.028mm
Let me know if I need to obtain any other measurements.
RE: JIS Spline Standards
I've skimmed through that thread but didn't see any spline standards. Also, I've looked through google and couldn't find any pdf's to assist. Hoping someone has a pdf I can use quickly.
thank you,
I understand, I’ll check other resources.
Here are a few JIS documents available through TechStreet.com:
JIS B 0006:1993 Technical drawings -- Representation of splines and serrations (pdf $68 USD)
JIS B 1601:1996 Straight-sided splines for cylindrical shafts with internal centering -- Dimensions, tolerances and verification (pdf $68 USD)
JIS B 1603:1995 Straight cylindrical involute splines -- side fit -- Generalities, dimensions and inspection (pdf $339 USD)
JIS B 4239:1999 Involute spline broaches (pdf $68 USD)
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
