Prevent Surface Penetration 1
Abq23
Student
Jan 26, 2023
3
When simulating a shaft-hub connection with a feather key, the feather key always penetrates the shaft and hub (see attachment).
A downward pulling force acts on the hub, which exerts a moment on the feather key.
My question would be, how can I prevent the penetration of the feather key into shaft and hub?
Info: All contact surfaces are defined as master and slave respectively and general contact I have selected as well.
Thanks in advance!
 https://files.engineering.com/getfile.aspx?folder=33a39bb6-f54b-4acd-827b-15712048df8b&file=Screenshot_2023-01-31_175028.png
What is the scale of the deformed shape plot ? Maybe mesh refinement will help.
I'm not an FEA guy but the print out looks a bit weird. Did you start it out with nearly zero radial and circumferential clearance? Just looks like the key was allowed to move.
The deformation scale is at 1537. I think its a bit too high. If I change it to 100 I get a decent result (see image).
Is the result then still reasonable ? And how high or low should the deformation scale be ?
Yes, the radial and circumferential clearance is just zero. There is no space between the contact surfaces.
Thank you for the quick answers.
This factor is used only for visualization (exaggerated deformation makes it easier to see how the model behaves), set it to 1 to see real deformations.
