FCI 70-2 Class-IV Seat Leakage Rate Calculation(what is the meaning Valve Rate Capacity???)
yldrmkara
TR
Hi All,
When we look at the value in the test standarts for Class IV control Valve, metal to metal
The standart says "Max. allowable leakage 0,01% of Valve Rate Capacity" . and i am wondering what is the meaning of "valve capacity" and how can we calculate and the final what except to this calcula. The bubble counter or max ml/m3 or ext...
No: i have a datasheet and where is the specifed on the sheet.
Thank you very much
For flow capacity, read Cv of the valve.
