Contact US
V-notch ball vs regular ball
Dear Gents, may I receive your comments
about reason to select V-Notch ball valve for an on-off
application instead of a regular one?
V-notch would have longer lead time and cost.
However maybe operation of it can be easier, less-torque etc.
Thanks for sharing.
RE: V-notch ball vs regular ball
The V notch is there to improve throttling characteristics, in a pure on-off application there wouldn't be any reason that I can see to use a V notch ball.
In some situations, the V-notch valve is lower cost than a full ball valve. On occasion they are used for on/off service. The primary reason is cost. The bare stem v-notch vale can be lower cost, especially with metal seats. May have less parts and lower torque to operate, so a smaller actuator. Another benefit of the v-notch valve is there is no cavity to trap media like there is in a ball valve with 2 seats. So build-up of pressure in the cavity is not a risk.
V notch opening torque would be much the same as its the seal pressure against the ball which dictates this.
Evan at full open there is a restriction in flow.
The valves only seal one way.
You would only select one if you had a high DP and needed to open the valve slowly or use it as a Control valve.
Normally not used for straightforward isolation but you could use in place of a globe or plug valve.
Thanks Gentlemen,
do you think that solid content in the fluid may be in favors of v-ball or vice versa?
"Solid content" is rather vague, but no standard valve likes abrasive solid content.
Wouldn't make any difference to me between those two.
High solids content could erode the downstream seat in a traditional ball valve when the valve operates. During operation, the downstream seat is exposed directly to the media flow. This is avoided with a v-notch type ball valve when the seat is on the upstream side of the valve.
But keep in mind that "solid content" is a very vague description. Most important is if there is proven history of use in the application. Only then can you be confident that it will work.
Scoring / abrasion of the ball is a major issue as well. This would apply just the same between the two if used as an on off valve.
I agree with all answers above.
However: A selection af any valve for any purpose is always depending on the exact conditions, well known to all: Fluid with chemical description, all additions and contaminations, pressuere, temperature, flow, behavior at emptied valve at surrounding temperature), pressure, regulation or on/off, number of operations per time, opening/closing time, pipeline size, selected valve size, price, total number of valves, actuation type, cost over lifetime including operational and replacing/repair cost/time etc. etc.
General advice:
For common fluids, pressure classes and 'normal' sizes, common ball valves tend mostly to be the best choice.
Steam and/or higher pressures and dimensions: V-notch to be evaluated, but not always the best.
Fluid with abrasion: Always a problem. Ballvalves not always the best solutions, V-notch to be considered, cermaic lining (costly) sometimes practical, sometimes gatevalves or special gate valves (espcially for high temperatures, pressures and dimensions) are the best.
Some special cases: Water at high pressure/dimentions(hydroelectrical power plants) or waste-water at larger dimensions (above 500mm) double eccentric ball valves (costly). Other valve-types also widely used.
Conclusion: more details needed for best advice.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
