Tmoose
- Apr 12, 2003
- 5,636
We are replacing some 75 HP 460 volt 900 rpm ODP motors from the 1970s. Frame 444TS.
The old probably original name plate also includes " Type K ".
As best I can tell Type K means 8.0 to 8.99 KVA per HP with locked rotor or somesuch .
I guess this is beyond, or in addition to the "Design" B which identifies a motor’s heavy load starting capability. “Design” classification ( A, B, C, or D) in the motor’s specifications.
It seems like modern motors do not mention "Type".
Is "Type" obsolete?
It appears Most modern 444TS motors are 100 HP or more.
I guess we'll just have to keep searching.
Is "Type" obsolete?
