Contact US
Three single-phase SSRs in place of one three-phase, with zero-cross
Hi Everyone,
We are having trouble getting three-phase sold-state relays. These are used to power a resistive heater load - in some instances a single heater is across two of the phases, and in others three heaters are distributed across the phases. I was able to find a single-phase SSR that otherwise has similar ratings to the normal 3Φ SSR we use (and for less than a third the cost!). Both SSRs have a zero-cross feature. Will there be any issue using three 1Φ SSRs? I am mainly worried that the zero-cross feature will not coordinate between phases, but I have trouble thinking that through.
Thanks!
RE: Three single-phase SSRs in place of one three-phase, with zero-cross
For simple on / off use, I don't understand there being an issue. You have 1 or 3 single phase objects that apparently have no sync required. That the SSRs are opto coupled, they are independent of their power source. I think it's irrelevant about phase sync and zero cross. Besides, the SSRs don't "know" or determine zero cross, they respond to it. Power control would work by using the thermal inertia of the heaters - X cycles on and Y cycles off.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
