Insert Spacing Buckling?
sarclee
105
Hi, I always concern about inter-rivet buckling if the spacing is too large...
What about insert in honeycomb panel if the spacing between insert is too large? Is there a general rule that we can use, or we just calculate the buckling based on the alu sheet?
Calculate buckling using sandwich panel properties, not facesheet.
