Is there a Equipment which has both AC and DC contactor for testing purpose
budhiman
60
Hello All,
Is anyone aware of a manufacturer or firm that makes (pre-fabricated) an enclosure with DC (up to 1000vdc) and AC contactor with 24vdc coil? Will be using this for testing PV inverters. The reason I ask is as pre-fabricated enclosure will be tested and listed as well. Attached is a sketch drawing for the application with a PV inverter.
Also, can I get some recommendations on 1000vdc/200A contactors with operating coils (UL listed)?
 https://files.engineering.com/getfile.aspx?folder=4493bdb7-267f-4a6f-9f40-8f71f9d3cdb7&file=Untitled.png
