Things are Starting to Heat Up - Part VII
thread1618-496010: Things are Starting to Warm Up.:
thread1618-496614: Things are Starting to Warm Up Part II:
thread1618-497017: Things are Starting to Warm Up Part III:
thread1618-497239: Things are Starting to Warm/Heat Up Part IV:
thread1618-497988: Things are Starting to Heat Up - Part V:
thread1618-498967: Things are Starting to Heat Up Part VI:
RE: Things are Starting to Heat Up - Part VII
Meanwhile, I've been banging on about urban heat islands (another heat effect!). Why it matters is that if you try and use the current temperature record and CO2 record to work out the climate sensitivity (CS), if you use data with lots of heating put in by cities, you'll overestimate CS, overestimate CO2's influence and overestimate the reduction in temperature seen by reducing CO2.
And luckily here we are - NA's trend in the last 50 years is 40% driven by UHI https://dailysceptic.org/2022/11/04/u-s-warming-ov... not CO2
Cheers
Greg Locock
https://www.cnn.com/2023/01/01/us/california-flood...
Cheers
Greg Locock
Some flood plains like the Nile river valley have fertile soil replenished by the floods, resulting in highly productive farmlands that support feeding a large population. People have historically needed to live near food and commerce centers; there's lots of reasons for living near the oceans, while "empty" places like the Sahara and Sonoran deserts stay empty. This predates property developers.
TTFN (ta ta for now)
It did until the Aswan High Dam was built. Now all the fertile soil is trapped behind the dam, and the Nile river valley is barren. Typical of man's attempts to control and improve upon the natural systems. The unintended consequences of acting without understanding are typically devastating. You'd think we'd learn to gather adequate factual data before charging ahead with half-baked 'solutions' to problems that may or may not exist, but apparently many either haven't learned that lesson, or just don't care, as long as they can make lots of money off of it (Yeah, I'm looking at you, Al Gore).
That was after millions of people wound up living there and got flooded out every year.
So, instead of doing the ecologically sound thing, they did the convenient thing, and destroyed the ecosystem. They tried to control nature, rather than adapt to it, and made a huge mess, for the people and the ecosystem. Now they're making the same blunder with temperature/climate.
And the alternative was to uproot millions of people and move into the desert? We're talking about moving 80% of Cairo out of the delta?
We all "know" that's stupid, but people are, in general, not great thinkers or planners. If anything, human stubbornness tends to keep them stuck in those situations; few actually say, "WTF, this is crazy" and go find greener pastures.
No different than finding that median retirement savings for 65-yr olds is only around $160k; the "safe withdrawal rate" of 4% would allow $6400/yr withdrawal from those savings. These people didn't "plan" to have only $6400/yr of "play" money, did they?
presumably the local taxes account for some of this localised expense ?
Cairo was there many hundreds of years before the dam was built.
Exactly my point; so who decided to build and not plan Cairo there without any consideration for NOT building Aswan hundreds years later? No one did, which is why Aswan had to be built to avoid moving or rebuilding the entirety of the largest city in the country.
My wife made a similar comment about our local Costco; "They should have planned for a larger parking lot 20 years ago to accommodate all the people today."
Doh!
That aside, my point stands. Building the dam destroyed the Nile river valley. The city that relied on the fertile soil for it's existence, now has nothing, because of a dam that was built to 'save' it. Every time we try to outsmart nature, we screw up nature and screw ourselves.
That brings us back once again to the subject - trying to control, or even affect, the climate is a fool's errand. We don't know which direction the global temperature will go next year, much less in next century. A trend is only a trend until it's not. The next generation may look back and think us mighty foolish, especially if the global average temperatures start dropping again.
https://www.cnn.com/2023/01/05/world/glaciers-melt...
https://www.cnn.com/2023/01/07/weather/flooding-he...
Added
https://www.cbsnews.com/news/coastal-residents-on-...
and another...
https://www.bbc.com/news/av/world-australia-642062...
It takes a storm to end a drought.
Our seasons have ALWAYS been less severe since 1861.
dik (Structural)
8 Jan 23 05:45
...so, how many 1000 year events can you get in a week? ponder
As many as they wish to create. Geo Engineering to the max.
Ignore the purple dashed trend line, that's someone trying to pick a trend from too little data. Bear in mind that the first 15 years of that plot was part of the real data used to train the models, therefore up to 1990 it merely indicates how well trained they are, not how good they are at predicting.
Why is CMIP6 doing such a bad job? Generally too little spatial resolution, but the fundamental model seems to be
(1)Ignoring Oceans -the 1 degree anomaly anomaly in 40 years is equivalent to 0.001 deg C of ocean warming.
(2)Ignoring Clouds
(3)Ignoring Secondary effects from changes in solar output
(4)Conscious or unconscious selection of worst case design decisions. You don't get grants if you predict there isn't a problem, and you don't get published if you go against the zeitgeist.
(5)over and underestimating feedback loops (clouds again)
(6)etc
Basically if you think CO2 is THE thermostat then you get this sort of result, because you assign all the other changes in the world since 1880 lumped in and correlated with the monotonic rise in CO2.
Cheers
Greg Locock
https://www.npr.org/2023/01/09/1147805696/climate-...
https://globalnews.ca/news/9399238/california-stor...
There is very little "perspective" given in California. Here we are always in one of the following situations:
a) In the middle of a drought.
b) Just got out of a drought.
c) Need to be prepared to go into a drought that will be right around the corner. (See the last atmospheric river event in 2016/2017).
We're just a relatively dry, arid state. We're not used to significant rain storms. We'll go years (maybe even decades) between events like we're experiencing now. As such, our infrastructure is not very well prepared to handle this degree of rain. Which means, roads will flood (or wash out completely), storm drains will get clogged up causing localized flooding.
In enough places, the brush cover has dried out died out to the point where we worry about mud slides as well.
Now, as far as the "drought" is concerned, these storms are a good thing. We'll get our reservoir levels up a bunch. My guess is that just about all of the reservoirs in NorCal will be filled this year. We'll get our snow back up as well. Snow pack is really important for us because that keeps of reservoirs full (from melting snow pack) for most of the year.
Trinity and Melonnes (with 2.4 M each) are closer to 25% of capacity.
Don Pedro (2M) is at about 75% of capacity (which is about the historical average).
San Luis (2M) is at about 40% of capacity.
McClure, Folsom, and Pine flat (with 3M between them) are all right about in line with historical averages, which should be a big improvement over last year.
Millerton (0.52M) and Parris (0.12M) are approaching capacity (i.e. more than 75% full).
I expect all of those numbers will go up significantly between now and the end of the month. The next question is what happens with the reservoirs in the other western states, especially Lake Mead. I have a feeling Lake Mead will go up much more slowly.... Since it's fed by the Colorado river and snow / rain in the Rockies, not the Sierra Nevadas.
"This BAMS special report presents assessments of how human-caused climate change may have affected the strength and likelihood of extreme events."
Or indeed, may not.
Cheers
Greg Locock
I left out Lake Mead and Lake Powell because those aren't reservoirs for California. Not as affected by the California rains / storms. The information I was reading about them is that they are entirely fed by the Colorado River. Which (if you look at the path of the Colorado on a map) is mainly fed by the Rockies rather than the Sierra Nevadas. I'm not sure how much these current rains have hit the Rockies.
Even if the Rockies have been affected by these storms, it wouldn't be until the snow melts in the spring that the flow of the Colorado would increase. I also wonder how many states syphon off water from this river before it gets to Lake Mead and Lake Powell. My understanding is that there are basic issues with these reservoirs and the current use of water consumption isn't sustainable. At least in the desert areas of Arizona / Nevada / California where it's water is being consumed.
However, my post was mostly about California's water storage system as a whole. Which should be in pretty decent shape after this winter (fingers crossed). While Southern California and the Central Valley are quite dry. There is enough water storage in NorCal and the Sierras to solve that problem.... especially if we would be more willing to use "recycled" water or grey water.
However, I think you are correct in saying the worst "water issues" are currently associated with Lake Mead. Even if that doesn't affect people where I live and the vast majority of Californians.
Nowhere in NorCal, the Bay Area, or the Central valley is dependent on Lake Mead. Not Fresno, Stockton, or Sacramento. Not anywhere in the Sierra Nevadas, Big Bear, Tahoe or Mammoth. Not Santa Barbara. Not LA or Orange County as far as I'm aware.
Maybe parts of San Diego, Riverside, or Imperial County? But, that is a relatively small sliver of the state. Not enough (IMO) for you to say that the state is "extremely dependent" on Lake Mead. Not sure what you're basing your claims upon.....
Not Lake Mead, per se, but its level is certainly indicative of the health of the Colorado River itself, for which SoCal, which you live in is dependent on.
ColumbiaColorado river is a high priority. If the situation remains the same, I can see in the future where the federal government may have to change this agreement... as a 'force majeure' causing a change to their water agreement. They need Lake Mead for water supply as well as Hydro power (a really clean source). I don't have a clue about how this will end. There are also international repercussions...-----*****-----
https://columbiainsight.org/for-drought-plagues-ca...
https://www.bbc.com/news/science-environment-64241...
https://www.aljazeera.com/economy/2023/1/13/exxonm...
There's a lot there, including a pretty good estimate of CO2 ppm and temp (fig 3 p7), and hence a pretty good estimate of CS, and figure demonstrating that GCMs tend to give higher estimates of CS than 2 other approaches(muffled laughter) fig 5 p9. Actually on further reading we're about in line with their high fossil fuel use case, so far as CO2 ppm (417), but I think that puts their temperature estimate about 0.2 high, so not quite as good as I'd thought, but significantly better than CMIP6.
Cheers
Greg Locock
Cheers
Greg Locock
What I found particularly useful was the plots that showed the expected range of fluctuation and the natural range of fluctuations. This certainly demonstrates one of the things that is most challenging about "climate modeling" and why a single year (or even a decade) of data can be significantly up or down from the prediction just based on natural fluctuation.
Personally, I like ExxonMobil because only their greases have useful product data sheets.
40 years ago, it wasn't even an ethics issue to do the study, just diligent science; the 40 years of suppressing the information is the unethical part, since they immediately cut the budget of those scientists the year after
Here's an earlier (1978) Exxon document https://insideclimatenews.org/wp-content/uploads/2...
There was nothing to do about this "study". It wasn't even a study, it was merely "mile high" / executive summary about research on a topic that they felt executives needed to be briefed about in case they were questioned about it.
The "study" was pretty clear about a number of things:
a) There wasn't any conclusive evidence that this was really happening (back in 1982-ish) and that given the margin of error caused by normal temperature variations, it would be mid 90's that any warming would actually be noticeable.
b) That the "results" from warming might be beneficial in some ways and negative in others. Result in more rain in certain areas, more drought in other areas.
c) That some scientists were concerned that the effects would not be reversible by the time the effects were noticeable enough to warrant action.
What action could Exxon have taken exactly? Let's say the CEO was "all in" and decided he had to campaign against fossil fuels and basically shut his company down. He would have been fired and replaced immediately.
Maybe, he could have spent their "public service money" less on wild life and endangered animals and such. Then put that money towards public service announcements about how the public should choose more fuel efficient cars. Would that have had any significant effect on consumer demand for fossil fuels?
Maybe he could have started a campaign to get rid of coal power plants and replace them with nuclear. Do you think the public would have supported that? Certainly not anywhere that coal is mined.
One of the problems with the left is they always thing there is some huge corporate "villain" out there like on some ridiculous episode of Captain Planet. LOL. The problem with global warning is about supply and demand. People want to be warm in the winter and comfortable in the summer. They want to be able to feed their families and live comfortably. Period. Abundant and cheap energy is what allows them to do all of this. So, unless you're willing to live "off the grid" like a hermit, compost your own feces and use that to grow your own crops then YOU are the closest thing to a villain that exists.
Providing a service or a commodity that the world consumers desperately want is NOT villainous.
If they found out there may be environmental problems and ignored the possibility, it could open a 'whole can of hurt' for them in the future, if they are taken to task about it.
Concern about the future, of our earth, is not a matter of 'right' or 'left'... only referenced so to vilify those concerned and to detract from what could be a real serious problem.
https://www.bbc.com/news/world-us-canada-64279891
https://www.cbsnews.com/news/climate-change-ocean-...
Including many politicians within those countries.
The other issue as I see it is the value many place on "research" by academia and govt, and mistrust of legitimate work by private industry. Having coordinated a Fortune 50's collegiate "research" program and worked in govt, I wouldn't trust either group to write a coherent report on current technology much less make meaningful predictions of the future.
Of course not. I don't think I ever implied that..... All I implied was that the left seems to view corporations that look after their own interests as some comical Captain Planet type villain. Rather than as totally normal people acting in a totally normal and legal way. Exxon is under ZERO obligation to save the earth. Understanding what academics are saying about their product's effect on the environment is not nefarious in any way. Say you (knowing what you know now!) were Exxon CEO back then. What could you have done that would have made a shred of difference in where we are now? The only think I can think of is PSA commercials encouraging energy conservation. Maybe investments in "bio-diesel" research. But, I seriously doubt any of that would have made a lick of difference.
Let's compare this to Ford and GM. Say, that there is a study that says (with a reasonable degree of certainty) something like spending too many hours in a car is bad for your health. What could they do about it? Stop selling cars? No, some other company would just ramp up their production of cars instead. They are not under any obligations to solve this problem. They shouldn't hide it (like tobacco companies did). They can conduct research to better understand why and how this is true.
What about soda companies? They know that sugary drinks contribute to obesity. Should they be responsible for slapping the coke out of a fat person's hand?! No. That person is responsible for his or her own actions. They can offer other beverages that are more healthy and see if consumers want to buy them. But, if consumers do NOT want to buy them what can they do?
Are we the US to blame because we have probably released more CO2 into the air than any other country over the last 100 years? Yes. Of course, China and other countries have now caught up to us. Do we just commit ritualistic hari-kari on our economy and move back to a pure rural economy? Would that even help? The second we move even 10% in that direction, there would be an insurrection and the government would be replaced with a new one that allowed people the freedom to live their lives how they prefer.
My point is there isn't a single "villain" we can point to for AGW. We can certainly make changes that will help:
2) Force the most least efficient (by CO2 emissions per MegaWatt of power) sources of energy to be completely replaced by more efficient sources of power.
3) Federal mandates on fuel efficiency in new cars, trucks and such.
4) Encourage other countries to do the same.
5) Impose tariffs on imported goods based on how much CO2 was used to produced them and ship them to the US.
6) Help re-plant areas of the world where forests have been clear cut. We already do that in North America. But, spend some money to figure out how best to do this in the millions of acres of rainforest that have been burned down.
It might be that they are all responsible and there does not appear to be a remedy. I just hope it is not as serious as it could be.
I think that honest greed would be what you are describing, but commerce is also about trust, so finding out that a company not only knew the truth, but lied and foisted the exact opposite position is a form of evil, and should make everyone trust them less, and trust their product advertisements and their products less. Of course, those who paid attention already knew that companies are in the business of lying, after all, when did most people actually need two entire quarters' area of shampoo to clean their hair? The cigarette companies and Perdue Pharma are examples of public lying about the nonvirtues of their products.
But, the big difference is that while wasting 3/4 of your shampoo purchase is certainly evil, it's not existential, but lying about a potential global calamity is evil at a new level. And let's just say that the "right" is wrong here, and seems to adhere themselves to liars and villains, and I have to wonder where their alleged moral compasses have gone.
Cheers
Greg Locock
I'm not surprised that's your position. You were probably a Captain Planet fan growing up and that's why you see them this way. LOL.
For what it's worth, can you point to anything that Exxon specifically said that's "lying about a potential calamity". I think most of the lying on this subject is done by politicians and activists. But, that's just my personal opinion.
Most of the "opposition" to AGW has always been more along the lines of.... "Wow, these claims are serious. How certain can we be about the timeline and the severity of the issues that will occur? Is that degree of certainty worth destroying the global economy? Are there other solutions that would be more reasonable? Other mitigation measures that would be more affordable?"
My stance has always been from an "energy economics" point of view. What's the most cost effective way of reducing CO2 emissions today? Maybe replace all coal power plants with combined cycle gas turbine plants instead? Maybe dramatically expand the use of nuclear power? Let's do THOSE things and do them NOW!!
Oh, wait, the hard core leftists / environmentalists won't let us do that because it's not a PEFECT solution?! Okay, I guess they're not really serious about CO2 reduction. We'll just have to putter along with more expensive, less efficient solutions than aren't very scalable (like solar and wind). We'll just have to continue puttering along until there are perfect solutions, we've made enough small and inefficient changes, or until the consequences become known and all we can do is mitigate.
...seems like a natural axiom or corollary... it's not a difficult leap.
This is the classic gaslighting approach, "I'm just asking questions" kind of thing. I've never seen Captain Planet. The bottom line is that Exxon cut funding on their own climate research and cast shade on climate change https://www.nytimes.com/2009/04/24/science/earth/2... just as you are casting shade by associating anyone who disagrees with you with Captain Planet.
https://insideclimatenews.org/news/22102015/Exxon-...
So, I'll ask my question, "Aren't there unintended consequences?"
You are doing exactly what Exxon Mobil has been doing. I'm hardly a poster child for climate change, and I've not advocated completely dropping fossil fuels; that's your contribution to the negative aspersions. I seriously wonder if you are really anywhere near the right of center position that you've previous claimed.
The IPCC's range for CS is no better despite 32 years of taxpayer funding.
The simple fit for the last 32 years says 2 deg C/doubling.
Cheers
Greg Locock
https://phys.org/news/2023-01-alarming-entire-glob...
https://www.cnn.com/videos/us/2023/01/17/arizona-w...
Not sure what you're getting at exactly. Yes, there are always unintended consequences when the government is interfering with the economy. Many times these unintended consequences directly eliminate any benefit intended by said actions. An example for AGW would be the following:
This is where we are now. My suggestions have been the following:
a) Get rid of coal in the US. Replace with more carbon friendly sources of power. I often say Gas Turbines because these are so relatively easy to build, permit, construct, and they would very dramatically reduce the CO2 footprint for that power.
b) Add tariffs on any imported goods based on various considerations (based on desire to reduce CO2 emissions in other countries).
b1) Any goods that were shipped more than a certain number of miles.
b2) Any goods manufactured in a country, province or state that gets more than x% of power from coal fired power plants.
b3) Any company that intentionally released certain gases that should be cleansed or flared or what not.
c) In a similar way, we could put different tariffs on imports from any country whose human rights record we don't like.
c1) If they don't allow women to vote.
c2) If gay people are imprisoned solely for being gay.
c3) If their constitution calls for the destruction of a particular race of people or a particular country that is part of the UN.
d) Requiring better gas mileage from cars. Any cars that don't have that mileage could be heavily taxed. Maybe those taxes can be used to fund rebates on the CO2 emission friendly cars. I.e. make the people who are buying the worst cars (based on C02 emissions) subsidize the purchases of low emission cars.
There can still be "unintended consequences". No doubt. But, the idea is to leave the market as alone as possible, but to add some extra costs to things that are inefficient and reduce the costs of things that are efficient.
My suggestions are a little bit "protectionist". This is because we know the consequences of these actions will be detrimental to the US consumer. The price of goods (and energy) will go up. But, the idea is to "game the system" in a way that the rest of the world is encouraged to also reduce their carbon emissions.
https://www.csagroup.org/wp-content/uploads/CSA-Gr...
Not gaslighting at all. Here we have one group of politicians activists saying, "We have special information about what is going to happen over the next 30 years. You need to take actions x, y and z to prevent catastrophe."
Sure, we have a group saying, "Your arguments aren't convincing. Nah, nah, nah.... My fingers are in my ears, I can't hear you." I'll refer to those people who don't believe that a) Global Warming is happening (even if the amount of warming is debatable), b) That atmospheric CO2 levels have been increasing exponentially, primarily due to human activity, c) That the scientific theory tying the two together is very solid.
Then we have another group saying that "anyone opposes actions x, y or z must be viewed as a flat earther, a terrible person. Probably white supremacist too. "
We have another group saying, "The first groups arguments demonstrate that something is happening pretty convincingly. But, the catastrophic effects they claim are not as convincing. Let's talk about the cost of 'mitigation measures' as opposed to only talking about the costs of 'prevention'. After all, those actions (partial prevention in conjunction with mitigation) are much more affordable and realistic.
That last group is the group that I'm in. Instead of calling everyone who disagrees with us evil, let's figure out what affordable actions we can agree to take NOW to help with the issue. Plan for future mitigation as well.
Cheers
Greg Locock
Response to a) Yes, the global temperature have been going up, not by as much as the alarmists would like us to believe from their cherry-picked data. Does that prove the temperature will continue to rise? As I said, a trend is only a trend until it's not. We don't know where the global average temperature will go next year, much less in the next century.
Response to b) The vast majority of the rise in atmospheric CO2 is the result of natural processes. In order to make it the result of human activity, you have to prove the 'forcing effect' of our minor contribution, which is still debatable.
Response to c) By the scientific definitions, AGW is not a scientific theory; it is a scientific hypothesis, one with as much evidence that doesn't support it, as evidence that does.
I mean no disrespect to you. You are free to believe differently than I do. However, I'm amazed that you're quibbling with me over the term "theory" vs "hypothesis". What is a theory, but a collection of hypothesis that join together to explain something?
Others on this forum will come down harder on you for not accepting items b and c of my statement. So, I'll leave that alone.
To all the rest of you, I will suggest that some "protectionist" actions related to AGW (as I have suggested) could still appeal to the BridgeSmith's of the world that don't buy into AGW at all. So, we have the potential to still move forward with collective political will even though we have serious belief and policy differences.
Your proposals 17 Jan 1829 would destroy the economy of many developed nations. Yet you rail against government intervention. You can't have it both ways.
Regarding government intervention, I think it needs to be done much LESS FREQUENTLY than we currently do it. However, if we want to make any progress on CO2 reduction, we must take some government action. I support actions to make the true cost (including the cost to society) of energy more reflected in the price of energy.
Now, the type of government actions that I prefer usually are more directly related to what their intent is. For example, I love the idea of gasoline taxes paying for the maintenance of our roads and highways. Why? Because that's taxing the people that use the government service. Right?
Building bridges, then charging a toll to anyone who uses them in order to pay off the construction loan and maintenance costs and such. That's great! The people who benefit from the bridge and use it are the ones who pay for it.
Similar things with electricity. Make the consumers of electricity pay for the construction of the plants and their effects. But, since coal has effects on the environment (i.e. something like 10 times the amount of CO2 emissions per MW power generated), it makes sense that this form of power should be dramatically more expensive when compared to other forms of generating power.
You should read up on the progression from hypothesis to theory, and the level of experimental evidence that is required to get there, before criticizing me for "quibbling" with you about it. There's not even close to enough congruent evidence for AGW to be considered a scientific theory, and enough evidence against it to raise questions of whether it can still be considered a valid scientific hypothesis.
I invite any reasoned debate on those subjects. I'm open to being convinced that what you asserted are true, but I haven't seen evidence thus far that amounts to more than speculation, conjecture, and alot of assumptions thrown into computer models. The old adage about computers (garbage in; garbage out), still holds true regardless of how 'advanced' the programming may be.
Before that, we must establish that CO2 reduction is beneficial, warranted, achievable, and affordable.
1829, or more correctly 18:29, was the clock time of your post, not the year.
Do you admit that we can predict the surface temperatures of the planets in our solar system that don't have atmosphere? And, that this prediction is pretty darn accurate? I'm talking Mercury, the moon, pluto, any terrestrial objects in our solar system that don't have their own atmosphere. I should point out that this prediction also, includes the difference between daytime and nighttime temperatures. That's step 1. Pretty hard to deny.
Step 2: would be to then admit that we can also predict the surface temperatures of other planets (the one with atmospheres) based on the gas content in their atmosphere. Mercury (no atmosphere) is half the distance to the sun compared to Venus. Yet, Venus has higher temperatures. It's atmosphere is 95% carbon dioxide. Demonstrating a pretty conclusive link between this atmosphere and an increase in temperatures compared to what a planet without an atmosphere would have. You can do similar things with Mars which has a VERY thin atmosphere (1% the pressure of ours).
Step 3: This step would be to look at the ice core data for the past few thousand years and admit that it shows a precipitous increase in atmospheric CO2 in the last hundred or so years. Same thing with the Mauna Loa data. Admit that this is a pretty strong indictor that there is a lot more CO2 in our air than there was 100 years ago.
Step 4: Did humans cause the increase in CO2, or was it natural. Or, is it a bit of both. See below link for the billions of tons of CO2 that are released each year from human activity. That 37 Billion tons each year. Just from fossil fuels.
https://www.statista.com/statistics/276629/global-...
Also, we must admit that the CO2 produced by burning fossil fuels has different carbon isotopes (or ratios of isotopes) than that release by regular plants. So, we can have a pretty good idea of how this (ratio of carbon isotopes) has changed over the last 50 years or more. This makes a pretty convincing case that fossil fuel emissions are a MAJOR source of the increased CO2. Make sense? Any major problems with my logic so far?
That's really all it takes for me to believe that there has been a man made change to the atmosphere in terms of CO2 content. And, that the CO2 changes are likely to cause some increase in temperature.
Now, I'm a skeptical person. So, I don't take the "fear mongering" of the alarmists very well. I believe in the basic premise that they're claiming. But, to move from their basic claims to catastrophe is a reach for me. However, I definitely see significant risk should we continue down the path exactly as we are. I feel they have made that case effectively and now I am more interested in how to handle our "solutions" in a way that doesn't kill more people than the original disease.
Step 5 the CO2 effect saturates at very low ppm, we are now seeing the effect of ovrloading the filter shape and just looking at the shoulders of the reponse (hence the dependence on doubling)
Step 6 there are far stronger and faster effects on short and long term temperature, especially the greenhouse effect of water vapor, and many transport and albedo effects of H20. 80% of the greenhouse effect is water vapor, we have no way of knowing how that has changed, anthropogenically or not.
Cheers
Greg Locock
That's certainly a possibility. I think there is enough "uncertainty" associated with the predictions that we probably shouldn't be committing economic suicide in order to prevent what we probably can't prevent anyway.
However, I would suggest that the it's also possible that we haven't seen the full effect yet and that it might get worse. There is soooo much normal variation in temperatures that it takes decades to see even a small amount of change above normal variations.
I am plenty willing to consider that there are other effects as well. Water Vapor, particulate carbon and such.
Predicting the surface temperature of a planet with no atmosphere is easy. All the gases, particulates, etc. and most of all, the varying levels and positions of water vapor swirling around in unpredictable patterns in our atmosphere is what makes prediction of temperatures on Earth virtually impossible.
I haven't seen evidence that we can accurately make those predictions, or even that there's a rational model that matches the surface temperatures of those planets. As far as I know, we don't have any idea what the surface temperature of Venus actually is, and if that's true, any models we have are worthless, because their accuracy cannot be verified.
37 Billion tons sounds like alot, but as a percentage of CO2 in the atmosphere, is it really? Look it up and get back to us.
In addition to what I wrote above, plants don't release CO2; they absorb it.
37 Billion tons of CO2 represents about 0.01% of the weight of all the CO2 in the atmosphere of the entire earth. So, in 10 years it will have increased the CO2 by 0.1%. It's not astronomically large. But, it's not insignificant. Especially if you add it up over a 100 years as it continues to increase.
Here's my math (on how the 37 billion tons of CO2 emissions compare to the total amount of CO2 in the atmosphere):
0.041028% (CO2 atmosphere volume) * 28.971 g/mole (average molar mass of dry air) / 44.0087 g/mole (CO2). This will give us 0.0623240117 as the mass percentage of CO2 for the atmosphere.
Then I get, from another source, that the total weight of the earth's atmosphere is about 5.5 quadrillion metric tons. Though this might include a significant weight from water vapor.
Total weight of atmosphere * mass percentage CO2 / weight of the CO2 that is released each year.
(5.5*10^15) * 0.062324 / (37*10^9) = 0.011%
Same things will happen in the UK and China and India and everywhere else. If I've got the choice between feeding my family today, vs taking a risk 20 years down the road, we're all going to make the same decision. Regardless of what Greta T, Al G, or John K tell us from their towers of "purity"..... just not going to happen. It goes completely against human nature.
However, there are plenty of things we can do to move in the right direction. Small, but meaningful steps that will make the problem less severe and reduce the cost of mitigation when the time comes.
...and what happens if you have a massive dought, and millions cannot feed their families. I wonder what sort of political effect that will have?
https://www.pthorticulture.com/en/training-center/....
The problem we have right now is we have a nebulous problem, "global warming". Does it mean there could be some flooding somewhere at some time? Sure. But, we don't know when and we don't really know where. Maybe they'll be drought too. But, we don't know when, we don't know where.
If you want me to stop feeding my family today and tomorrow because of some vague promise of future misery, that's a pretty hard sell. Not many people are going to be willing to do that.
Now, we might be willing to tighten our belts a bit and make some minor sacrifices. Like gradually increasing the price of certain energy and lowering the price of other energy so that we don't produce so much CO2 when we cool are house in the summer. I'm getting solar panels installed on my roof right now. It's a pretty big expenditure. But, I think it's worth it in the long run. In the short run (over the next 7 years that I'll be paying off the loan), it will be a major drain on our monthly income.
That's you choosing to do something that's in your own best interest. That's different than the government, say, banning natural gas appliances. If installing solar panels had a payback period longer than the life of the panels, so it was a cost to you, rather than an investment, would you still be doing it?
Probably not. I don't have enough disposable income to make it worth the added expense. If I were rich and wanted to feel better about my carbon footprint, then I might have. But, I'm not.
Personally, I'm not quite convinced about the numbers they claim I'll see in 20+ years.... that's when previous generations of solar panels started really breaking down. But, I think it will be worth it overall. Especially with the government rebate that I'll see on my taxes next year.
Did anybody hear Al Gore's speech today? I won't comment.
https://www.youtube.com/watch?v=MBKZWKeKYqE
There are plenty of ways to lower the price of energy. For example, CA puts all kinds of additional restrictions on refineries over what type of gasoline they must produce. This dramatically increases the cost of gasoline in CA. Eliminate those unnecessary regulations and the price goes down. Not below the "natural" level, of course.
However, that's not what I was talking about. What I was talking about was direct subsidies from one type of power to another. If we're saying that coal is bad (because it produces so much more CO2 per MW of power produced) then the extra taxes that coal pays goes directly to subsidize the cost of building CO2 free nuclear plants.
We're saying there is a price to society for emitting too much CO2. So, if you want the cost of power to better include that cost this is the way to do it. Force the more problematic power to pay for its own replacement. Once we've done that with coal, then we decide what to do next. It might be similar. Tax the most inefficient power plants (in terms of CO2 emissions) and use those taxes to again pay for nuclear (solar and wind as well, if you like).
I'm saying that's an unproven assumption, and as such, we shouldn't be interfering in the free market price of any energy sources.
The key word there is "if". We haven't established that global temperatures will go up, and if they do go up, on the whole, it will be harmful to humans or the planet.
It's been shown mathematically that adapting to climate change, whatever direction it goes, will be far less expensive than the measures proposed to stop the Earth from warming. Why would we spend more on attempted prevention of something that may not happen, rather than dealing with the realities and challenges as they present themselves, so that we know what we need to do.
BridgeSmith is correct. Interfering with the free market inevitably causes unforeseen consequences.
That's fair enough. That's your belief. I think there are plenty of us who are more concerned about this issue. Therefore, at this point, it's a matter of public and political opinion. If enough of us have a similar belief they we will take some actions. I just hope they are rational and reasonable actions and not "green new deal" type actions.
Do you have a reference for this?
Note: I tend to agree that "mitigation" measures for the problems that do occur are a lot more efficient than trying to stop a nebulous event or action from occurring. However, there are certainly some lower cost actions that we can take today (and that we are already taking today) that we should continue in the hopes of avoiding the worst aspects of global warming.
Cheers
Greg Locock
A la Paul R. Ehrlich types over the past 70 years. Play it again, Sam. Just plug in the current hysteria to generate fear. The "experts" are on the dole with grants so they will parrot the party line and hockey stick the model outputs.
Mean while, Gore, Obama and Kerry build mansions on the sea shore that the "experts" are warning will be flooded in 7 years from the ice caps melting due to warming caused by burning FFs and farting cows.
The emperor has no clothes!
Skip,
Just traded in my OLD subtlety...
for a NUance!
...and, as we have observed, laissez faire capitalism may have a similar effect.
The storm was so bad the President of the United States required a visit. The beach had to be steamrolled. Did they file an EIR?
https://www.bbc.com/news/world-asia-64440319
Cheers
Greg Locock
https://euroweeklynews.com/2023/01/30/climate-chan...
https://www.cnn.com/2023/01/30/world/global-warmin...
TLDR Summary: A study used artificial neural networks – a type of machine learning or artificial intelligence – to predict when the world would hit 1.5 or 2.0 degrees Celsius over pre-industrial levels.
Cheers
Greg Locock
So whatever happens it is going to get warmer, adaptation will be both cheaper and less painful than any serious and politically impossible reduction in CO2 production. Silly targets like 50% net zero by 2030 are just politics, they aren't achievable, and attempts to meet them without proper planning will just cause waste and chaos.
Cheers
Greg Locock
a) There are relatively cheap and easy methods to slow down the increase by taking measures today. They won't stop the warming. But, slow it down to the point where it's easier to adapt to as it occurs. I'm talking about eliminating coal power plants. I'm talking about switching to nuclear, etc.
b) Adaptation will likely be cheaper for most places. But, that may not be feasible in some areas. Some places will become unlivable. Maybe because they're just too hot in the summer months. Maybe because of rise in sea levels.
c) We're also not the only ones on the planet. We might really damage the rest of the animal populations which, in general, would not be able to adapt in that time frame. It is possible that many animals will have to migrate to other lands, may die off or greatly reduce in number. Whole eco systems could be dramatically affected. All of these things could affect our ability to mass produce food at a rate to support our population.
I'm not predicting "the end of the world" like the AOC types tend to. I'm not even saying that this is a true "existential crisis" like the Gen Z folks have been led to believe. But, there is a middle ground here that exists between "there's nothing to worry about, we're better off ignoring the whole concept" and "we're all going to die in 20 years if we don't cripple our economy today".
https://www.newscientist.com/article/2356654-earth...
https://www.theguardian.com/environment/2023/jan/3...
It's speculation, not fact, that slowing our output of CO2 will slow the warming of the planet. There's also only hypotheses predicting that the warming will continue, as opposed to the current warming being part of a cycle that could take a downturn at any time.
Those are not cheap and easy methods, certainly not in the short term. shuttering a coal fired power plant that still has many years of service life left, and building a new plant of some other type, is a huge waste of resources and a significant cost to the customers of the utility.
I agree with building nuclear power plants. We have to get past the fearmongering about nuclear power plants. All the major incidents with nuclear power were at plants built in the 70s (or before) with mostly 60s era 'electronics' in the control and monitoring systems. Modern plants, especially the Thorium reactors coupled to breeder reactors, are very safe, in all aspects. That includes not only making nuclear waste from the reactor that could be used in a dirty bomb inaccessible, but also providing the ability to reprocess existing nuclear waste, drastically reducing its volume and radioactivity.
I agree, IF CO2 is driving the climate change, then lowering it is "better".
I think it's reasonable to think that our CO2 is having some impact on the environment, so reducing it is "better".
But making everything more expense (as the cost of energy goes up) isn't helping the bulk of humanity
But I see the current situation as an agenda for a subset of humanity to impose control over the rest. And if their measures don't change the climate trajectory significantly it won't be "I guess we were wrong, sorry" but "we were too late, if only you had listened".
Actually, it is pretty cheap and easy. Shutting down a coal plant is really easy. It emits something like 10 times the amount of CO2 as gas turbines do (per mega watt of power produced). So, just shutting one down an replacing it with a combined cycle gas turbine would be pretty darn quick and easy. I should point out the lead time to engineer and build a gas turbine plant is not very long (less than 1/10th the time it would take nuclear plant to get built).
And, the power from gas turbines is no more than a coal plant. Probably less.
The idea of expanding nuclear takes political will, which we don't really have right now. But, if we had the will to do it then it's cheap, clean, CO2 free and very, very safe. The biggest problem is the lead time and the politics of it. The green extremists (the same ones most concerned about global warming) will fight it every step of the way.
But, all of these expenses when added together will be fractions of what our government spends subsidizing solar panels on rich people's homes, or giving rebates to rick people when they buy a Tesla. And, the benefit goes to everyone, not just the virtue signaling, latte sipping rick liberals.
My biggest complaint is that we are wasting all kinds of tax payer money on programs that are VERY inefficient in terms of their ability to reduce CO2 emissions per dollar spent.
https://www.iea.org/data-and-statistics/charts/ful...
The political issue is that the first world is practically irrelevant, the increase in CO2 output is driven by China, India and other 'developing' nations (Indonesia is big and has lots of poor quality coal, for example, so when they industrialise what are they going to use?), so you have to put your nukes there.
Cheers
Greg Locock
Take the case of Australia, for example. A large emitter of CO2 per capita, as dik likes to point out, but an insignificant emitter globally.
Australia has an almost limitless amount of quality coal which is easily mined, and depends mostly on coal for its power. It also has gas, mostly coal seam gas, but not so much.
So a mixture of power sources, including coal, gas, wind, solar. What's notably missing? Nuclear, for a variety of reasons, but mostly because the same types (Extinction Rebellion and others) who call for all coal plants to be shut down immediately are the very ones who protest so heavily against nuclear power. Politicians listen to the squeaky wheel, so no nuclear plants will be built in Australia for the foreseeable future.
Then there are countries which have to import their power feedstock. Japan, China, India, etc. They get it from the most reliable and economical source, Australia. The market will rule, in spite of government intervention or international protocols.
https://www.eia.gov/international/analysis/country...
Perhaps a turbine manufacturer could license the technology to China so they can steal it and start building their own units instead of coal.
That would be an indirect way to cut the world's CO2 production.
I recall looking this up awhile ago and finding out that the difference was huge. But, I can't find the sources I read back then.
However, the following article suggests it's more like 7.5 to 1.0 . However, that's with post production carbon capture.... maybe that's not implemented yet? And, closer to the 2 to 1 that you suggested without carbon capture for the gas turbines.
https://www.sciencedirect.com/science/article/pii/...
Also, the numbers I looked at recently suggest that China (while rapidly increasing their CO2 emissions) actually has a lot of low CO2 emission power as well. I certainly agree that places like China (as well as India and others) are a major issue with slowing down CO2 output. That's mostly because of a rapidly expanding economy. Not because their power is any less clean than ours. It's more because their economy is expanding so quickly that power demand is increasing so dang fast.
https://ourworldindata.org/electricity-mix
Hokie -
Australia, as I understand it has dramatically moved away from coal power in recent years. And, plans to do even more of that over the next decade. Though they are still extracting their coal and selling it to other nations for power.
This is some of the goofiness of these policies. So, their energy prices will go up (because coal is so plentiful in Aus) when they shut down those plants. But, they will digging up the same amount of coal (probably more) and shipping it off to other countries instead. The result will be a net increase in the CO2 emissions per ton of coal extracted.... because of the cost of shipping that coal to china or india or where ever. I think the Australian government (if they're really serious about reducing CO2 emissions) needs to tax that coal extraction to subsidize their cleaner energy. Reducing the costs for the consumers of clean energy and increasing the costs for consumers of coal energy.
https://www.spglobal.com/commodityinsights/en/mark...
China's per capita carbon is half the US and India's is about 1/10. They get blamed because their larger population yields a greater footprint. It's the political thing to do... and is an excuse for not doing anything. No one seems to be doing much about climate change, and we'll likely have to see how things will change. Once they start changing, there may be no turning back.
Your LP is stuck.
Josh,
Don't worry about that. Australian governments, both at national and state level, have never seen a tax they didn't like. Queensland, where I live and where most of the coal is extracted, has just increased its royalty/tax so that the highest value coal will be taxed at 40%.
https://www.afr.com/companies/energy/soaring-price...'s%20previous%20coal%20royalty%20regime,prices%20above%20%24150%20a%20tonne.&text=The%20new%20system%20introduces%20three,prices%20above%20%24300%20a%20tonne.
https://edition.cnn.com/2023/01/31/africa/south-af...
Another report:
https://www.opml.co.uk/blog/south-africa-s-crippli...
So they train the neural network on models which are known to run hot, and then predict it'll get hotter sooner than we thought. Do you realise how utterly stupid that is?
Cheers
Greg Locock
Reality stubbornly refuses to follow the models.
Note that typically they train the models up to 1990, its only after that they are running blind.
Cheers
Greg Locock
Common plastics have better hydrogen to carbon ratios than coal. The CO2 emissions from burning plastic will be lower than coal and the CO2 emissions will be more beneficial than recycling plastic. It's a double win.
I'm glad someone finally commented on my linked article. That article is the epitome of stupid global warming reporting. Why would a Neural Network be better than the model built by and expert? Do the reporters really not understand that neural networks cannot think for themselves? They must be trained to think.... They will think whatever you want them to think based on the input your force them to learn.
That was truly some of the dumbest reporting I've reporting I've ever read.
