There seems to be 2 different ratings used for current in power cables. Im not totally sure what the relevance of each is.
Lets look at this cable
Qualtech 313010-01
The datasheet says it is rated for 13Amps
However, there is a table for appropriate currents used for power transmission
according to this, when the wires are bundled, it can only do 2.3/3.6Amps
When do we need to use the standard AWG power transmission rules? Is this for wires that go through UL approval testing? or as the document says, the National Electrical Code.
I realize national electric code is for NFPA 70 and used with it which means in the USA that we need to follow it as OSHA calls this out. So Why are there 2 sets of currents ratings? Im honestly confused by the regulations, any help is appreciated.
Qualtech 313010-01
