DOL Starter Control Scheme 1
Histor
SG
Please help me to understand the DOL Starter control scheme.
Below attached is the DOL starter control scheme. The original scheme vendor provided has LCP (Local Control panel) with Start, E-stop and R/M selection.
I want Field E-Stop only. So I have marked up the changes to study on my own. Please let me know if the comments I've marked would be enough to use field E-Stop.
Please suggest me what to do?
I need two signals from E-Stop. First Signal to be hardwired to Starter and tapped to PLC/SCADA. Second Signal hardwired Starter control circuit. Thanks.
Looks correct to me.
