Lisp for translating the layers
Histor
SG
I have a drawing exported from 3D to 2D. In AutoCAD 2D Drawing all the layers needs to be laytransed to background layer (grey).
when I do laytrans, Some of the layers (LayerA and layerC), shall be excluded from above mentioned laytrans.
I am manually doing the laytrans. But I want some one of your help to get lisp for performing this activity.
A "script" (*.scr file) could probably handle this, depending on your layer naming convention.
Here's one site with info:
The script file would look something like:
layer
color
8 (or other background color)
color
(desired color here)
LayerA,layerc
(2 blank lines, to end the layer command)
Or if excluded layers should just keep original color, maybe this:
layer
lock
LayerA,layerc
color
8
unlock
LayerA,layerc
