Greetings. In Workbench (V10) is there a contact or support that allows for sliding as well as rotation (separation)? Think of a plate that is in contact with a surface, but has a moment applied to it causing it to rotate off the plate, but and edge is constrained to remain in contact. Like a peeling action.
The point indicated would be both sliding and in contact. In my actual use case, the plate is circular, and is constrained 360deg by a flexible retainer. I am trying to determine the limits of the retainer as the plate rotates up.
