Contact US
Just Passed NICET III (FAS) - Fire Cert Academy Is The Way
Hi all,
I just passed my NICET III for Fire Alarm Systems and wanted to pass along a helpful tip to all of you out there studying for NICET.
Fire Cert Academy provides a subscription service that gives you access to hundreds of randomized practice tests for all levels of NICET in ALL disciplines. You have the option to choose timed or un-timed if you are just studying casually...answers are provided at the end of each exam with code references.
Allowable references and helpful tips are provided on some questions/answers and the price for subscription service is really reasonable considering you can pay $200+ for an NTC book to help you study or $40+ dollars for one single practice test from NICET.org where they don't even give you the answers.
I found this to be one of the most helpful and efficient uses of my time while studying since we all know that the key to passing these exams is knowing your codebooks inside and out and being able to look up answers quickly using the index etc.
Here are all the levels/disciplines they provide practice tests for:
Fire Alarm Systems Level I – IV
Water-Based Systems Level I – IV
Special Hazards Systems Level I – II
Inspection & Testing of Fire Alarm Systems Level I – II
Inspection & Testing of Water-Based Systems Level I – III
NFPA Certified Fire Protection Specialist (CFPS)
Check it out or take a free sample test on Fire Cert Academy's website, I hope it helps all of you who are studying for your next exam!
Cheers
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
