Tony, it depends on your use. What industry, and what product are you making?
If you buy from a quality distributor for normal ASME, say a 2'x2' plates from 100 (40' x 8') heat, it will almost all be tested for impact - they just don't report it on the MTR. Ask for it.
If you are buying lower grade materials, say cheap W44, or consumer type materials, you can get the impact done yourself, impact/heat is around $300 CAD. They probably won't have mill results as normal.
