Has anyone come across a practical reference which deals with thermal load in structural design?
Depending on node restraints and member releases, member forces can be quite high, often seeming unbelievable.
The query is for structures which don't have allowance for movement (such as sliding bearings).
Basically for structures with normal bolted connections, without oversized/slotted holes. Or even welded structures.
