Power Transmission Ideas for a Coaxial Wind Turbine
so the problem I'm dealing with is I have one generator, which does not accept any shafts (the generator itself for some reason i dont understand has a shaft, sigh.) and I will put this somewhere in the wind turbine nacelle or tower.
The wind turbine layers both will rotate in the same direction, so the shafts coming out from (inside the nacelle) them will also rotate in the same direction as each other. What is the most efficient way of delivering power to this generator? (this is the problem statement)
my considerations so far:
since the generator can't accept any shafts theres no chance of putting it into the nacelle. i will have to suspend it in the turbine tower somehow (below the nacelle) so then
I need a mechanical power transmission element that will be at the centre of the nacelle, and be input with the mechanical power of both turbine shafts, and change the axis of rotation from horizontal to vertical. then transfer this power to another shaft, and this shaft would of course be facing downwards and this shaft would rotate a cylinder whose purpose it is to fit into the generator's shaft.
i have included a work of art to illustrate what i mean:
i will then need to ensure this setup doesn't fall apart with bearings and whatnot but idk how that works
note: its not like i want to reinvent the wheel but i couldn't find any co axial hawt models online.
btw I can make the shafts of the turbines rotate in the opposite direction to each other too if that helps power transmission
thanks guys
RE: Power Transmission Ideas for a Coaxial Wind Turbine
Possible solutions: 1) run both turbine shafts into a speed increaser gearbox assembly with only one output (given the positional requirements, it means running one of the turbine jackshafts back past the generator to the gearbox). 2) If you try to do what you drew, you WILL need some type of clutch arrangement as the turbine shafts will not necessarily be operating at exactly the same speed ... UNLESS both blades are affixed to only ONE shaft. If the single shaft with two blades is used, you have what is essentially a right-angle (speed increasing) gear located where your "mystery element" sits.
Other considerations - mounting the generator vertically inside the "tower" portion will make it virtually inaccessible for repair purposes. Do you really want to go there? Typical crane cost to lift out a conventional wind generator (horizontal mount) on a modern tower runs about 60-100k USD per lift. That would be one lift to take the damaged unit down, and one lift to put the replacement (or repaired) unit up - EACH TIME IT FAILS. In comparison, the cost of a new 3 MW generator itself only runs about 90-120k USD.
Converting energy to motion for more than half a century
It's not reinventing the wheel - it's reinventing the drag sled.
**an exception of sorts is multi-stage compressors and turbines where the fluid is restricted from bypassing the blades. Bypassing is the actual limitation of wind turbines. Trying to extract too much energy makes a barrier to fluid flow deflecting the wind around the blades where the energy cannot be extracted.
thanks a lot for the detailed response
firstly I should have clarified d this is a miniature wind turbine project. you should quite easily be able to carry the full model in your hands lol.
(1) No it is not intended to be direct drive. I had just forgotten to include Gearboxes lol.
(2) the generator's ratings are unknown as of yet. I will be told these tomrrow
(3) yes the shafts will most definitely spin at different speeds.
(4) I do not understand how a single shaft attached to both layers of blades could work and I don't know any gear that can do what you describe. Maybe a bevel gear pair? but I heard they are terribly inefficient
My main question is,
what kind of power transmission element can solve the problem of being input with two shafts spinning in the same direction at different speeds and needing to transmit the sum of that rotary power down the turbine tower?
This I think is the crux of the problem right now,
https://khkgears.net/new/bevel_gears.html
For balancing purposes it might be better to lock them in phase, turning at the same rate. This will ensure the downwind blades have a controlled disturbance from the upwind blades.
