Mounting a Hinge on Aluminum Honeycomb
If I would like to mount a hinge on honeycomb panel, what would be the common way to do it: just purely rely on potting or use insert?
Thank you!
Thank you!
RE: Mounting a Hinge on Aluminum Honeycomb
In either case, to get the panel pull thru/out capability you will need test data for the particular configuration.
