Compressor room filtration and Ventilation
Dear all
We have a compressor room at our facility in which 3 rotary screw compressors are installed. We are planning to enclose the room and add filters to the air inlets. The ventilation after enclosing and filtering needs to be pre-considered before proposing any design.
Any information which can help in achieving the desired goal is appreciated. The purpose of doing all this design change is to avoid contaminants entering the compressor. We are getting high contamination values in the oil analysis report and are trying to get rid of this issue.
RE: Compressor room filtration and Ventilation
Also consider cooling requirements in an enclosed room. Unusually compressors need a room of a specific volume. So you may need to provide more air than just what gets compressed.
There are guidelines for sizing air openings for boiler rooms in the National fire codes (NFPA), eventhough not applicable in your case, you may find that information suitable since air compressors "suck " air just as boiler oil and gas burners do. You'll have to do some research on the net to find the applicable NFPA code.
You should look into adding pre-cleaners to the air intakes if you don't already have them.
For example https://www.donaldson.com/en-us/engine/filters/pro... (first Google result - I have no affiliation)
In your original post you state
I read this as getting excessive oil in the compressed air system. If this is correct, enclosing the compressor room is not going to solve your problem since air entering the compressor is not the source of the oil contamination. The problem is the compressors themselves. They need to be serviced and/or replaced.
What is the compressed air being used for?
