Moment releases continuous vs pinned 3
Eradul
LK
Hi !
I have done simple truss analysis in SAP2000 while mistakenly providing moment releases of members as continuous instead pinned while I'm drawing the truss. However, later I changed the releases by Assign>Frame>Releases/Partial fixity>ticked all releases except axial load. However, still, I'm receiving bending moments for the members. Can anyone tell me the reason? [glasses]
 https://files.engineering.com/getfile.aspx?folder=ecc3e6be-108e-4336-9dd3-f2e5269abaa9&file=truss.sdb
If they are in fact all modeled as pinned, you would need some kind of load along the member not at a node. I uniform load on the top chord or member self-weight will cause this effect. Sloppy un-merged modeling where the members are not quite aligned at the nodes will also cause member moment.
The model attached does not have the members modelled as pinned. Select all of the members and release moments at either end.
I agree with kjm93, that model does not have any member end releases assigned to the truss elements.
