DXF Export Flat Pattern with PMI
AnnaRochester
Student
Nov 20, 2022
1
i want to create a flat pattern from a sheet metal in Siemens NX and export it with PMI and bend parameters to a DXF file using vb.net.
i have the code for creating the flat pattern and it's exporting the drawing file to DXF File with just the bend parameters. However the PMI is created in the trimetric view.And i cannot find a way to move the PMI to flat pattern view,so that i can export it to the dxf file.
Any help that i could get would be great
