NickParker
- Sep 1, 2017
- 446
What is the IEC /NEC code to determine the size of the ground cable (PE) for the equipment frame grounding to the nearest grounding bar (local bonding)?
This is in addition to the ground cable that runs along with phase conductors from the source to the equipment.
In my case the size of the ground cable which runs from the source is same as that of phase conductor. Should the local bonding cable be same size or be downsized?
