Contact US
Coal tar epoxy coating VS skotchkote 134 for protection against corrosion resistance
Hello All,
We have vertical turbine water pump that has cast iron parts and we are thinking to coat them. We have two options. Can you recommend, based on your past expereince, which one can provide more reliable long term resistance against corrosion. Coal tar epoxy coating or skotchkote 134?
RE: Coal tar epoxy coating VS skotchkote 134 for protection against corrosion resistance
I don't think you want the hassle of a thermoset epoxy. That would rule out the Scotchkote 134. What led you to single out these two products? What characteristics do they have ths you desire.
There are companies that specialize in these types of coatings. I would consult one of them.
International 300V would be my alternative suggestion without any additional details. It holds up well in fast moving water around boat hulls. This is assuming you're not experiencing erosion or cavitation.
Many coal tar epoxies are carcinogenic. Just a heads up.
https://www.sciencedirect.com/topics/materials-sci...
Most industrial coatings are. Take proper precautions.
again, a heads up.
There are likely 50 different coatings that would work fine.
Getting the correct surface preparation and application is 99% of your issue.
I would look at something other than epoxies, such as urethanes.
Good luck sourcing urethanes with the current supply chain issues.
These days that advice should be to find out what your local suppliers have available.
I have heard of cases where one coating is available in Houston but not in Chicago.
Seems very common these days.
I'm having a hard time sourcing polyurea greases and that's a problem because they don't always play well with other types.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
