Ionut Cosmin
Aerospace
Hello all,
I am trying to determine what should be the first eigen mode frequency for a subassembly if the requirement is known for the assembly.
For example, let' say I have a robotic arm which has a requirement that the first natural freq should be higher than 70 Hz. On this arm I have an equipment, let's say a camera. How do I determine the requirement for minimum freq of the camera? is there an equation that can provide this answer? or should I just take the same requirement from the main assembly, the arm?
Cosmin
Cosmin
