cyriousn
- Jul 19, 2017
- 30
Hi everyone, I've been tasked with trying to figure out a way to extend an existing air insulated 345kV ring bus in a congested substation. There is not enough room to extend it with air insulated equipment so I'm left wondering if it could be done with exterior GIS equipment. Each end of the extension would be tied into the existing 345kv high-bus and there would be two underground lines coming up in between. The two lines coming up are both generating sources so we may need two breakers in between those sources. We only have about 250 x 60 ft to work with. This is my first time looking into GIS so any help would be much appreciated getting a reality check on the footprint I'm looking at here.
