Inserting Section Tables Into Mathcad Prime
Aiden Wilkins
GB
Hi all,
I have been looking into this all morning but just cannot figure it out. I am looking for the best way to input steel section tables (sizes and data - I, E, Z etc.) into Mathcad so that I do not have to manually type in every single property for each calc.
I have tried a few things using READEXCEL and copy/pasting excel tables (I have the data in excel already) but nothing is yet to work. I do not have use of the "Excel Component" function.
Any help would be much appreciated. Excel file attached for use/reference.
Aiden.
 https://files.engineering.com/getfile.aspx?folder=ac627b76-6aa1-49a4-9772-a815bf30ec92&file=Steel_Sections.xlsx
make sure the path for the excel file is correct and you use the right syntax.
I have my excel file located in the same folder as the mathcad, so my function reads like this READEXCEL(".\aisc-shapes-database-v15.0xlsx","Database v15!A1:CC2092")
if the excel does not live in the same folder you need to define the file path correctly.
After that you have a table - I built a function to query the table for a defined beam size as follows:
I just match the index of my new BEAM table with the property I want to extract and define it.
