dik
- Apr 13, 2001
- 26,063
Does anyone have a handy solution for a load applied by a plate across an HSS section, where the buckling of the tube wall may likely occur. This would take account of the radiused corners.
The actual application is a 1" cap plate welded to a W column and the HSS beam is welded to this cap plate to develop a small moment. The moment force being treated as a line load across the HSS beam at the edge of the cap plate.
Thanks...
Thanks...
