I am having issues with the Undo function when I create a sketch in Creo Parametric drawing. For example, whenever I make a change to a sketch line, the Undo button would be grayed out, so I am unable to undo this change. I tried to change certain parameters in the Options menu that are related to the Undo function, but nothing worked. Is there a way to allow any change to a sketch object in Creo Paramatric drawing?
