Fastener joint modeling using single RBE2 instead of CBUSH w/ "spider" RBE2
hootrpootr
Aerospace
I have a question I was hoping you all could answer. A coworker sent me an FE model that he created, where he modeled a bolted joint using just an RBE2 element (with DOFs in 123) to connect the matching holes in 2 plates. I would never do this; my preferred modeling method would be to add a CBUSH element between the two holes and then connect each end to their respective plate with an RBE2.
Is it even possible to extract usable MPC forces from my coworker's model? When I plot the MPC forces marker, I get 0 lbf in every direction. Is this due to the summation of forces at the independent node or something? I know that RBE2s are infinitely stiff, so I suspect any forces/stresses at this type of joint wouldn't even be realistic or worth assessing.
I've attached a picture of a quick FEA mockup of a joint with just an RBE2 vs my preferred method of a CBUSH w/ RBE2s.
Thanks for the input!
Ugh, both methods are awful (his more so). Sigh. Why do people insist on modelling the holes then stick an infinitely stiff element in the “hole”? (Yeah, I get it, its easy to blindly automesh using the CAD model).
I would not model the holes in the plates. For a two strap joint, I would connect a node in each plate (strap) with a CBUSH (if Nastran) or a fastener element (if Abaqus). For a three or more strap joint, a Ruttman type modelling method is needed to ensure fastener continuity.
I agree ... but sort dismissed by the OP, no?
SWComposites, so for Nastran do you remove the hole in the surface adding a node at the center, then connect those via a CBUSH?
Essentially, yes. Remove the holes in the CAD model or surface before meshing. Then figure out how to force the mesh to have nodes at the fasteners. Or use a code with meshless fastener elements.
if you have holes (like in a 3D mesh CAD part), retain the center point/vector and delete the hoe.
if you are doing a 2D model, mesh as you like and use element results (shear/in) to derive fastener loads.
obviously use more attention for discrete high load fasteners (wing attach) than "ordinary" skin/frame of skin/stringer rivets.
rb - LOL, "use element results (shear/in) to derive fastener loads" is a nearly lost art. It seems these days that if the FEM postprocessor doesn't auto plot a (often rubbish) result, then analysts have no clue how to determine it. I can't count the times I almost lost my mind when I asked for a (balanced) free body diagram and got a nearly unintelligible Patran image generated by the internal FBD generator. Sigh.
ditto ... sigh
I'm not trying to take over this thread but @rb1957 can you elaborate on "use element results (shear/in) to derive fastener loads."
you can get shear flow from the FEM. sometimes directly from the elements, sometimes with some manipulation.
eg a skin splice between two elements may be directly Fxy, from FE output.
shear flow into a frame cap (or shear splice) may require some additional element addition/subtraction.
then what is the typical rivet spacing
and so the typical rivet load = (load/in)/(rivets/in)
