Re rating with lost document of material 1
INSP79
IQ
I have no data for LPG vessel in-service since 1981 , now it has metal loss corrosion , wanting to re-rating but have no data for anything of material , construction code . I sow in OSHA web site answered for this situation which says” assume lowest value of recalculation variables “
I ask if can i find this recommendation in API ,NBIC ???
Without construction details / inspections etc, I think what you have isn't an LPG vessel, it's a lump of scrap metal.
I doubt anyone will approve this.
Morten,
you need to attach it properly.
This is a link to your hard drive.... Or link to the post where it is listed. I assume the boiler exploded?
@Littleinch,
Thanks [rednose]
--- Best regards, Morten Andersen
Actually, as the OP noted, there are often provisions to rerate certain types of pipe and equipment using lowest values. Not being a BPV expert, I don't know what exactly may apply for ASME ratings, however it is not uncommon to see old used vessels, surely all not porting original docs, being recycled into suitable applications in varied oilfield services. There is a usually healthy trade in used equipment in the oilfield second hand markets. It may still have some value other than scrap. No harm in checking that out.
Einstein gave the same test to students every year. When asked why he would do something like that, "Because the answers had changed."
If worthile, You have to make a complet inspection, ultrasonic measurementes, metalographic replicas and make a fitness for service according ASME FSS, othewise as others said you have a mount of scrap.
luis
As far as actually using them in a typical oil gas project, yes. And I didn't say it was easy. I'm only saying that they probably still have a value considerably higher than just scrap metal value, even when sold without docs. A typical LPG vessel (bullet tank? for example) has many potential uses, many of which may not be connected with oil and gas at all.
What's wrong with taking a coupon to analyze?
It usually requires lowest reading of several coupons and results in Swiss cheese.
I thought the object was PMI, NDE can tell you the minimun thickness.
