Are there any issues with jointing a cable with copper screen onto a cable with aluminium screen?
electrical429
51
Do you need a special kind of joint like bimetalic one?
Only if you want to prevent corrosion at the joint.
Isn't most double shielded cable tin plated copper braid over aluminum foil? I don't see any issues that stand out.
