Contact US
Need the formula
Need the formula
Need the formula
I think/hope this is the right forum for this question.
I need the formula to calculate: Time(minutes) to melt 1 pound steel (power in joules).
Thank you
RE: Need the formula
Joules is energy, not power. Watts is power. Not sure how many Joules are required to melt steel on a per-pound basis, but once you decide how rapidly you want to melt the steel then the Joules divided by the time in seconds gives the Watts.
Joules and Watts are always capitalized as they are named for the people sharing those names. This is true of many SI units.
You'll likely need two numbers. One is the amount of energy to heat the steel from room temperature to the melting point and the second for how much energy is required to change the phase from solid to liquid.
The specific heat and heat capacity for various types of steel are searchable on the web. Then a brute force total heat divided by the amount of heat you can provide will give you a start, after which you'll need to account for various heat losses, thermal conductivity/diffusivity of the steel, etc.
Is this for school?
TTFN (ta ta for now)
Are you actually going to just be melting 1 lb?
Smaller furnaces will tend to be less efficient (more heat loss).
Quote (EdStainless)
And not to forget extra metal in the crucible that needs to be melted but cannot be poured into product. I forget the term but there is waste metal in every melt.
Usually called the 'heel'.
There is also some metal lost to slag (oxidation).
If a 1T furnace uses 625kWh to melt a ton of steel then a 1kg furnace would not need 625Wh, but more likely 750-800Wh.
We had a small lab induction furnace. We charged almost 6lb and made 5lb pours.
It was on a 5kW power supply and melts took us about 20 min (it wasn't steel, we needed more power).
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
