Tmoose
- Apr 12, 2003
- 5,636
We are looking to have some large metalastik style bushings made.
So far I'm finding the typical elastomer is some flavor of vulcanized natural rubber.
Often bonded only to the inner sleeve.
Is the rubber bought as vulcanized sheet? Or vulcanized as part of bonding the rubber to the inner shell?
Specifying or even describing Natural Rubber materials seems shrouded in mystery. At least to me.
Swedish specs seem to specify Natural rubber as either -
Type 1 high tensile properties and good compression set properties
Type 2.moderate tensile properties and moderate compression set properties
ASTM D2000 (mirrored by SAE J200) lumps Natural rubber, reclaimed rubber, SBR, butyl, EP polybutadiene, polyisoprene into Classification AA.
Their basic AA requirements (Table 6) are limited to durometer, tensile strength, elongation, before and after heat aged aging.
Oil resistance is not among the requirements.
Any comments are appreciated.
thanks,
Dan T
Steel inner and out sleeves nominally ~ 0.2" thick.
IDs 5.7" to 7" . ODs 6.75" to 8.0". 8" to 9.5" long.
thanks,
Dan T
