The first launch of the Space Launch System [SLS]
FYI ONLY...
If I have seen farther than others, it is because I have stood on the shoulders of giants." --Sir Isaac Newton
The first launch of the Space Launch System [SLS] live on August 29th, 2022! The launch is currently scheduled for 0833 AM USA-EST.
NASA's epic Artemis 1 moon mission launch is just 1 week away
https://www.space.com/nasa-artemis-1-mission-launc...
I'm getting that old 'tingle'... anticipation mixed with apprehension and awe and admiration and pride and 'wonder-how-heck'... as I did watching the Saturn 5 launches as a kid.
The Long Journey Beyond Reach: Saturn 5 Launch History
https://orbitaltoday.com/2022/05/16/the-long-journ...
Trivia... [before?] E.F. Bruhn wrote the first edition of the staggering Analysis and Design of Flight Vehicle Structures, he partially wrote and edited the [more obscure] book Analysis and Design of Missile Structures. E.F. Bruhn, J.I. Orlando, J.F. Meyers
Regards, Wil Taylor
o Trust - But Verify!
Regards, Wil Taylor
RE: The first launch of the Space Launch System [SLS]
I'm not sure NASA really knows how to do this now. They are good at building and operating probes to the planets and the Webb telescope is a marvel to be sure. This SLS has been a scheduling and financial debacle for a decade. There are serious problems with the ground support equipment and launch tower. Remember how poorly the rocket performed during the first wet test too. I've been expecting some type of problem to arise this week and won't be surprised to see it rolled back to the assembly building. If that happens, then I expect the SpaceX starship to launch first. That would probably kill the SLS program.
I hope I'm wrong and hope for great success. BUT- after following this program for years I really will be surprised if this thing ever launches a manned mission.
Brad Waybright
The more you know, the more you know you don't know.
For a few extreme launch conditions, SpaceX has 'bit-the-bullet' and accepted loss of the first stage of launch vehicles... no landing gear, no grid-fins and full expenditure of fuel.
Also, the the super-sized SpaceX launch vehicle has yet to lift-off with all [33] stage-1 engines running. That cacophony of engines seems pretty sketchy/chancy to me. I figured that the first stage would/should have flown a typical launch profile, by now, with a throw-away dummy upper-stage.
But, hey... my SWAG... what do I know...?
Regards, Wil Taylor
Brad Waybright
A test case could have been tried years ago using the original Atlas design... which was a clever single stage to-orbit concept... with additions of the [2] booster engines/structure/fairings that fed from the core-tank... then separated from core booster/tank when no-longer needed... and the core engine pushed itself and the payload to orbit.
The core booster consisted of the center engine... which I think the was optimized for higher altitude... mounted to the tank tank-body with guidance.
The jettisoned booster section... could have had tested with a parachute recovery system and an ocean flotation system plus recovery beacons. DANG opportunity missed. This section was 'ripe' for re-use.
Regards, Wil Taylor
SpaceX's progress is reminiscent of the early USAF missile development. For about 6-months in the 1950s, my dad was in Thor Missile training at Vandenberg AFB CA. Thor and Atlas were being built/tested/launched/tweaked from Vandenberg and Cape Canaveral ~1-X week.
I remember watching ascending missiles from VAFB... weekly. They were dead silent until the 'roar' finally reached-us miles away in Santa Barbara. My Dad couldn't call us... be he let Mom know the night before a launch 'when' to have us kids outdoors playing at a 'certain time'.
PS: Officer and Senior NCO wives [spouses] always know secret stuff... that is why they have clearances ~equal to their GI husbands [spouses].
PS: While working at Santa Maria CA airport, some of our friends worked at VAFB [just-over the low coastal mountains from SM] and would let us know when missile launches were happening. It was cool! One time a bunch-of-us saw a double Minuteman III 'salvo [war] launch'. Kinda pretty, kinda eerie, kinda scary experience.
Regards, Wil Taylor
SpaceX doesn't have that restriction - recall their earlier, nearly comic, failures. So they get an organization that accepts the need to stop and fix problems as they occur rather than just barrel along.
Neither group is careless, but the NASA effort expends brainpower in trying to imagine everything that could possibly go wrong and SpaceX, having looked at only a smaller set of likely conditions, does more testing to see what does go wrong. This narrows the effort considerably at the cost of sometimes turning hardware into a scattering of fragments.
Since it has turned out that NASA could not, in fact, imagine everything that could possibly go wrong, it's clearly not an infallible strategy, in spite of the extra time and expense, but when they go to Congress they have piles of evidence that they had done everything they knew in order to fight off the vultures.
If Congress were to fund smaller steps in NASA programs, then Congress could also just pull the plug very easily. The extra funding and extra time is not a NASA initiated problem; it's a Congressional lack of consistency in support problem with funding and time being the symptoms of dysfunction in Congress.
A visible difference I attribute to the two methods is the exhaust plumes of the Saturn V engines vs the SpaceX engines. I think part of trying to imagine every failure is a tendency to make everything as perfect as possible. If nothing varies then nothing can vary too much.
Look at the transition where the darker shield gas layer is finally heated to incandescence on the Saturn V F-1 engine. That is about as steady a transition as one can expect - just a few percent variation it the distance from the nozzle exit.
SpaceX doesn't use that method, but the exhaust plume is noticeably more chaotic. I expect a large amount of money was spent on that near perfect performance on the F-1 engines.
The Saturn V transition is seen here: https://youtu.be/2cldgl9IIyY?t=345
The Falcon engine is seen here: https://youtu.be/976LHTpnZkY?t=24 and https://www.youtube.com/watch?v=D6mzGeXXn_A
They both work, but the F-1 is practically art and Falcon is git-er-done and the difference in price is obvious.
And don't forget all SpaceX launches are licensed by the FAA ... so they're not completely uncontrolled cowboys.
Link
Brad Waybright
As I recall, instability in the Saturn V F-1 engines, drove innovation towards stability in the F-1 and the SSMEs' with their god-awful million #-thrust engines'. AND having fewer engines resulted in lower potential destructive harmonics.
The Russians tried the use of many small engines for their 'moon-rocket'... and harmonics/instability destroyed all of the vehicles in 1st stage flight. Suggest You go-to Youtube search...
"Soviet N1 Moon Rocket \ The Largest Rocket we have forgotten".
'The Largest Rocket Explosion Ever - The Soviet N1 Moon Rocket Failure'
The brutal facts of today's world, are that that nationally-funded research is the foundation for basic knowledge and change-to-come... and is never cheap. What follows are innovators who take that hoard of hard-earned knowledge/experience and shape/reshape future.
NASA and the Russian Space agency have-had-to... and are-still... learning everything up-front. SpaceX and the all the other Space Agencies... India, Japan, China, PRK, etc... and component developers/contractors are the 'second mouse'**...
YES... BIG/EXPENSIVE/THROW-AWAY launch vehicles 'seem old fashioned'... but for super-sized payloads, the jury is out.
Regardless, SLS and SpaceX Starship... and their derivatives... must be fundamentally safe and reliable.##
Anyway... I love quotes... I believe that these are relevant Fud-4-Thot... IE: perspective.
##"As a pilot, only two bad things can happen to you… and one of them (eventually) will.
a. One day you will walk out to the aircraft knowing that it is your last flight.
b. One day you will walk out to the aircraft not knowing that it is your last flight."
--Unknown
"Experience is one thing you can't get for nothing." -- Oscar Wilde
"In wisdom gathered over time I have found that every experience is a form of exploration." --Ansel Adams
"Experience is a brutal teacher, but you learn. My God, do you learn." --C.S. Lewis
"The early bird gets the worm, but the second mouse** gets the cheese." – unknown
Regards, Wil Taylor
I wonder if the Artemis 1st Stage Core booster... with SRBs... would be a 'similar-to-diameter' match for the SpaceX Starship Upper [payload/fly-back] stage?
IF the SpaceX Starship 1st stage gives them 'trouble' due to the huge number of engines... and IF the Artemis 1st Stage core and SRBs are highly reliable [although expensive]... could the 'two' be mated/flown' together?
I think I'll stop daydreaming and go back-to-work.
Regards, Wil Taylor
TTFN (ta ta for now)
Keep on dreamin' Wil
Next step is trans-lunar insertion 'burn'.
This is heady stuff!
https://www.space.com/nasa-artemis-1-moon-mission-...
more...
Translunar insertion is successful!
https://edition.cnn.com/2022/11/16/world/artemis-1...
Regards, Wil Taylor
o For those who believe, no proof is required; for those who cannot believe, no proof is possible. [variation, Stuart Chase]
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion", HBA forum]
o Only fools and charlatans know everything and understand everything." -Anton Chekhov
I always wondered why the base of launch vehicles [with engines, structure and guidance] wasn't separated from the tank-section...
One word: Pogo
IIRC the Atlas had the worst pogo effect ever experienced by an astronaut. Not a concern for ICBM's.
If there's flexibility in the propulsion unit's coupling to the fuel tanks (center of mass) I can see the pogo effect taking over.
Sorry, it took a while for the coin to drop on your question...
Thinking about rockets a lot these days. I wonder why... ;)
Ho Hum... SLS has been a staggering success start to finish... with exception of 'anticipated' damage to the Launch-tower/gantry... mind boggling heat/sonic/over-pressures.
Regards, Wil Taylor
Still, nicely done even with the US Congress ready to meddle at the drop of a hat and change funding, goals, favored suppliers ... That's the heavy lifting that should be recognized.
a different learning might have been ... can we recover with a helicopter, like some other outfit (NZ ?) does.
"Those side booster are "just" solid fuel cannisters...." HUHHH? For the original Atlas, these engines were liquid fuel and feed off the main tank... until shut-down, the then the 'Booster Package' separated [jettisoned]. After jettison, the core engine [designed for higher altitudes] pushed the tank [with remaining fuel/O2] to max V... sub-orbit or orbit depending on payload. This is why the Atlas was often called a 1-1/2-stage launch vehicle. Here is a brief history of this remarkable 'family' of launch vehicles...
How The Atlas Rocket Evolved Over 60 Years https://www.youtube.com/watch?v=TeGmIeu0xvI
Or were You referring to something else?
PS: The floor(s) of the ocean(s) away from Cape Canaveral and Vandenberg AFB are littered with tons US launch vehicle debris. I wonder if 'adversaries' ever used(use) stealth submarines to recover [or simply photo] debris for 'study? Hmmmmmm.
Regards, Wil Taylor
Anyone ever look into NERVA rocket engines?
Specific impulse = 841 seconds (vacuum)
The engines under the Shuttle / SLS are less than 500 seconds.
