PVC coating primer adhesive alternative?
Rizzi94
Petroleum
SA
I really need some help. I work for a pvc coating company and a adhesive primer is required for the coating process. However, due to some unforeseen circumstances, the shipment for the adhesive has been delayed. I have to find an alternative till the shipment arrives. Does anyone know if something that can be found at the construction store be used temporarily? Currently we use a solvent based primer adhesive. Any help would be immensely appreciated.
