Scania obscure detains
Hi All. I have a relatively modern DSC9 where I have removed the electronic controls and attached a lever and pushrod to operate the power control.
Does anyone know:
1) If there is a TDC sensor ?
2) Does the #1 injector piezo sensor fire on needle lift and/or needle drop ?
3) What injector advance would be appropriate for fixed timing ?
If I can determine these, I anticipate using an oscilloscope to measure and adjust injector timing via an added screw on top of the timing plunger. At present, it is just set by what sounds right.
TIA
Does anyone know:
TIA
