Saveas translated
blitz97
79
Anybody using SE22MP7 with teamcenter 13? We just upgraded from SE20 TC12.
Save-as -> translate will no longer just translate the "displayed only parts" under export options. It translates everything in your assembly. I found the attached PR on the Siemens website with no solution given.
Hoping someone has found a solution. As a workaround, I found that if you open the assembly in an unmanaged environment, it will then only export the "display only" parts.
 https://files.engineering.com/getfile.aspx?folder=887f2bab-628d-498e-8ebf-6815ad74e33f&file=PR10251748.pdf
