valvetrain forces
valvetrain forces
can somebody point me to info on valvetrain forces in a pushrod engine, please?
im primarilly looking for valvetip force and lobe/lifter force on a v-8, (e.g. ls1), preferably real/measured.
RE: valvetrain forces
So that the valve tip doesn't bounce off of the lifter/bucket/shim/cam lobe/whatever and destroy the valvetrain. It's not all that complicated.
Mention of not exceeding spring force. Is that true in a condition of spring harmonics, or valve float?
so would anybody know where i can find a graph of valve tip force in a ls1 with stock cam (or similar engine)?
this is an example of a zetec engine (comparison of two cams):
Think about the physics of what would happen at the point on the cam lobe where the valve acceleration changes sign during valve opening if the force applied to accelerate the valve is greater than the force applied by the spring to keep the valve tip in contact with the cam lobe.
This is called valve float, and it's bad. Usually really bad.
Cheers
Greg Locock
1. Spring force. This is very simple to determine. This force varies in direct proportion to valve lift. When you rotate the engine very slowly, this will be the contact force.
2. Inertial force. This is directly proportional to valve acceleration which can be determined from the valve lift profile (2nd derivative of lift). This force is +ve (adds to the spring force) at low valve lifts and -ve at higher lifts. This force increases with engine speed.
3. Gas force. Usually less significant than 1 and 2. Difficult to analyse precisely without actual data on cylinder and port pressure. Varies with engine speed and load and is obviously different for intake and exhaust valves.
je suis charlie
Of course we don't know what OP is really after so maybe it matters and maybe not.
grunt, add to it: friction, contact angles rocker/pushrod and rocker valve.
swinny, did you see the graph i posted?
these are the most popular u.s. engines. such measurements were surely done thousands of times by gm and others. i would have thought this was "common knowledge".
1400 N ~ 315 lbs.
Looks like like Crower hot rod 8500 rpm springs are only 174 lbs open.
http://www.crower.com/media/pdf/sport%20compact%20...
348 > 315
looking at the graph, can you explain where the second 1400 peak comes from? i can see how the valve deccelerates when banging onto the seat, but how would that translate into contackt force? inertia would make the rocker tip lift, no?
there is no second peak here:
(doesnt upload, will try later.)
https://files.engineering.com/getfile.aspx?folder=...
edit: uploaddoesn work.
