ASME section VIII Swivel Flanges : for subsea applications
Is there any code or standard which provides for the design of Swivel flanges? ASME B 16.5 provides for the design of lap joint, slip-on, weld neck flanges etc. but there is no mention of swivel flanges. There are two components to the swivel flange, the hub and the collar. All the mating parts for the bolts and gaskets are as per NPS, B 16.5 and 16.20 but when it comes to the hub I am not able to get a reference or design rule. I have the calculation note based on ASME section VIII div. 2 in Excel and for a given pressure, temperature, axial force, Bending moment, etc. I can vary the hub dimension till it passes. But this trial and error approach just doesn't seem right. Would appreciate if anyone could provide some guidance.
RE: ASME section VIII Swivel Flanges : for subsea applications
To me that could easily be a lap joint flange where the ring can swivel around the pipe.
Or do you mean one which can accept some level of axial misalignment?
Like the attached says, there is no standard for these custom designed items.(scroll down a bit)
https://www.wermac.org/flanges/swivel_ring_flange....
ASME VIII App 2 I think is notorious for saying flanges which comply to codes like B16.5 and 17D are over stressed.
However the design code for boilers and pipelines allow you to use fittings made to set standards listed in the code.
The recommended practice is not to stress analyse a fitting supplied to a given standard....
Just start a new one with a good title and add details such as what you're doing and why.
We are not a free engineering service so add what you've done to try and find this out, why there isn't anyone in your organisation to ask and what it is you're trying to calculate. Your question currently doesn't make sense.
But start a new thread.
Not fully aware of Sec.viii.Div.2.
Further, Note I'm also a engineer and has capability screw down all problems and find solutions too.If don't want to share knowledge it's ok.
I thaught its knowledge sharing platform.Futher I'm a free consultant because it's satisfy me well to help others.
Thank you .For suggestions I will start with new thread.
don't be so priockly. Your question (one line) gives no information as to what you're talking about.
ASME VIII appendix 2 I think is the key. If you search "ASME VIII appendix 2" on this site you may find this has been discussed many times before.
