>You could also have mentioned the problems of soil variability, sample disturbance, testing relevance, matric suction, tension cracks, climate change and vegetation unknowns. We seem to be in agreement about the risk of trying to be too clever about analysing stresses.
Yes, and all models require simplifications
. Many of these issues can be dealt with using current software but practically the problem is now getting the inputs / lab data for them.
>Bishop’s method has the merits of simplicity and honesty: the internal stresses can’t be determined from statics so we’ll just ignore them and use a healthy safety factor - which is also needed for all the other unknowns. This approach of course is generally a bit over-conservative unless the soil is weaker lower down. In this case Spencer’s method should be safer, although if there’s a weak lower stratum and a composite slip surface then a wedge analysis seems more sensible.
I have heard some people argue that we should switch back to simpler methods that can be checked by hand if an LE analysis is going to be used; They might have a case.
Maybe but then, despite the points you've raised Spencer and Morgenstern-Price give essentially the exact same answer, or at least close enough that you shouldn't need to worry about it if you have any understanding of the extent of all of the other simplifying assumptions in the model.
>Krahn’s paper doesn’t explain why a half-sine function is better than Spencer’s (and other functions are of course available). Some people may be attracted to a half-sine because it seems more sophisticated, but Spencer’s approach seems more plausible to me as well as having the advantage of simplicity
Practically speaking the methods return essentially the same answer and with modern computer software it really makes no difference, you can run all of the avaialable methods in Slope/W on tens of thousands of slip surfaces in a couple of minutes.
>So to return to my original question, when it’s appropriate to use the relative simplicity of method of slices software, why not use a typical shear stress profile derived from generic FE analyses instead of seemingly arbitrary functions based on horizontal forces? Why not try to take advantage of insights from FE over the last few decades since the methods of Spencer and others were introduced?
Because you can just run an FE analysis and uses the stresses in the LE analysis, which is what Krahn proposed 20 years ago? If you need something more complicated than that, use FE; if you need something less, current LE methods are adequate. From what I understand there aren't really many practical cases where the difference between FE, LE with FE derived stresses, and LE makes a difference. Sure I guess you could try coming up with a revised LE method (I haven't done a literature search, but maybe someone has already done this). Thing is, the odds of getting any serious uptake of it are pretty close to nil, and there aren't really any practical advantages of doing so. If you want a better understanding of the stress distribution, use an FE model (they are widely available and similarly easy to run now).
